Mirror / Rotate
Toli
Reply to Pantaleao.
Thank you for your feedback. I program since 1982, so I am quite old in the branch too!
Usually, you are right. However, the changes in the look and feel are marginal and in the functionality are none. Taking into the consideration the gain in usability, I suppose that the users will be happy. If not and should I receive more negative feedback, it wouldn't be so difficult to revert to the initial UI.
Reply to Pantaleao.
Could you make the initial UI as a UI choice?
This will be neither easy nor straightforward.
However, I might implement it time available and / or more people complaining about it.
The difference is not only about two missing buttons, but the fact that now all the options are on Buttons, not RadioButtons anymore. The best solution would probably be to use two different forms and load whichever appropriate at runtime (the user's choice, remembered in the Ini File)
Reply to Pantaleao.
...If not and should I receive more negative feedback...
Please don't get me wrong, as I wasn't saying that your plugin UI is bad,...
...I was just anticipating not only this kind of request but also...
...the changes in the look and feel are marginal and in the functionality are none. Taking into the consideration the gain in usability...
...looking at PdN as a whole. Imagine what would result if each plugin author decides doing his 'smal' deviation from the Standard L&F Design Guidelines* of a plugin-oriented, architecture-driven project, just for the sake of usability; each of them could be great in isolation but in the context of the project as a whole... That's why we must resist the 'temptation'...
And that was my only concern. Thanks again and congratulations! :)
* Oh yes, I think we have one: "Windows L&F Design Guidelines", Microsoft Press.
"Be who you are and say what you feel because those who mind don't matter and those who matter don't mind."
~Dr. Seuss
Thank you for your appreciation.
Less CPU and Memory overhead is an old habit of mine, from the era when CPU frequency was around 0.87 MHz, bandwidth was 8 bits and RAM 64 KB...
By the way, do you think that I should make a little tutorial about how to make a faster plugin or something? (I am a professor too, not only a programmer)
Not that i'm madjik nor a c# progammer, but i believe that there are people who would benefit greatly with a lesson like that :D
Please check the new binary and source code at the beggining of the thread. I think these are almost final, because I am not going to work at this plugin in the near future unless serios bugs / drawbacks are found.
I made another plugin, Smooth, check that one too, please.
:shock: are my plugin so that you think and say I need some lessons to adapt them ?
:lol: In fact I agree, I want to have some lessons on how to make my plugins better... I'm learning C# by myself so this will be a great help!
:lol:
NO! I don't think that your plugins are slow, or that you need a lesson to improve them, cause I simply don't know c# that well and I didn't read the source of any plugin, so I'm not the person to point fingers at who needs one or two lessons on programming.
And for the record, I do think your plugin have a nice renderization algorithm, they're quick enough! :D
I created a localizable version of the Plugin.
It autodetects the current language in Paint.NET and changes the Plugin Title (the MenuItem) and the UI accordingly.
Just download the new binary and the Ini File and place them both in the Effects Folder.
Feel free to improve my translations and / or add new languages.
Enjoy!
Could you put the version number and release date on your thread's subject line (edit the first post), so we can see at a glance whether it's been updated or not? (i.e. "Mirror/Rotate v.2.0, 12 Nov 2007") Thanks!
  • 2 years later...
  • 6 months later...
The link is given two posts above yours. I'll update the first post with the correct link right now.
  • 6 years later...
