K_I_N_G 0 Posted April 26, 2009 Report Share Posted April 26, 2009 I've seen all the rose tutorials on the forum but I wanted mine to have a stem instead of an abstract looking piece. So I thought I'd share how to do so: 1. Make a circle selection or draw one. Center the selection. 2. Render clouds at default settings with the inside of the circle selected. 3. Run drop ripple. 4. Run dents. 5. Run twist. 6. Duplicate layer, go to adjustments and flip the layer horizontally. 7. Lower the opacity to about 120 or use overlay. 8. Use color tint or any other method to color the rose. Using the same plugs can achieve different affects, then using the 'wire' tutorial you can make a stem. My finished rose: Quote Bloody Tentacles Tut (fixed link) My gallery Link to post Share on other sites
Goonfella 220 Posted May 4, 2009 Report Share Posted May 4, 2009 Want to make multiple selections like in this tut? - http://www.psionic3d.co.uk/tutorials/shiphull.html First to get more than one selection active draw the first one, then hold down `Cntrl' as you make the second, not `shift' as in the tut, and it will be added to the first. To make the many sided selections , for example an L shaped one, do one rectangle selection but don`t move the cursor away from it. Then just do another rectangle horizontally(or vertically depending on which way the first one went)and when you are finished the two selections should merge into one `L' shape. And you can keep adding on to create the many sided selections shown. Also I found that if you make one large selection and want to split it in two, right click on the mouse as you make the selection and that section will disappear leaving two separate ones. I don`t think this has been mentioned yet, apologies if it has, but it is such a useful thing to know I felt I better add it to this thread. Happy PDNing! Quote Please feel free to visit my Gallery on PDNFans And my Alternatives to PDN Link to post Share on other sites
Blooper 0 Posted May 4, 2009 Author Report Share Posted May 4, 2009 Hasn't been mentioned, but like I said if it's in the help files, you don't need to say it Quote http://synthastic.deviantart.com http://soundcloud.com/siderealenterprise Lockerz invites are available, PM me Link to post Share on other sites
Goonfella 220 Posted May 4, 2009 Report Share Posted May 4, 2009 sorry, never realized it was there. :oops: Quote Please feel free to visit my Gallery on PDNFans And my Alternatives to PDN Link to post Share on other sites
Dianna 1 Posted June 23, 2009 Report Share Posted June 23, 2009 What is PDN? Newbie here Quote Link to post Share on other sites
Ash 10 Posted June 23, 2009 Report Share Posted June 23, 2009 Paint Dot NET Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to post Share on other sites
himself22 1 Posted July 12, 2009 Report Share Posted July 12, 2009 I have a tip: When in doubt, use polar inversion at these settings: Quote "The truth is just an excuse for having a lack of imagination." Photobucket sucks! Link to post Share on other sites
EscapistAngel 0 Posted July 24, 2009 Report Share Posted July 24, 2009 Not actually related to PdN, but: Try and keep the folder where you save your final/WIP/source images in order. On my old computer, I just saved everything in the same folder with the thought "Nah, they'll be there and I'll find them" After _some_ time of PdNing, there were several hundred files in the same folder. And you want to find a single one. Hopeless. Nowadays, I have a folder for source images, a folder for WIPs, a folder for final images, one for *.pdn:s and one for *.png:s. And every major, larger project deserves its own folder. Quote Please forgive my possible complaints. I'm but an annoying little perfectionist when it comes to using english... "I tremble in the presence of your terrifying skills of gardening." Link to post Share on other sites
Blooper 0 Posted July 24, 2009 Author Report Share Posted July 24, 2009 I don't save PNG's, only PDNs. I use Upload To if I need to show it to someone. Quote http://synthastic.deviantart.com http://soundcloud.com/siderealenterprise Lockerz invites are available, PM me Link to post Share on other sites
flip 3 Posted July 25, 2009 Report Share Posted July 25, 2009 I have a tip:When in doubt, use polar inversion at these settings: That's not a good tip at all if you're serious. Quote Gallery Link to post Share on other sites
Blooper 0 Posted July 25, 2009 Author Report Share Posted July 25, 2009 Oh wow, I just saw that. I really suggest you don't follow that tip, or else you'll have obvious polar inversion in every single one of your pieces. If your picture seems too monotone, flatten - copy - undo twice - paste in a new layer. Duplicate this. Run autolevel on the top layer. Set it to difference and merge it with the layer just under it. Set the resulting layer to screen/additive/color dodge and adjust the opacity. If your base image was already very bright, you can invert the Intensity (if you don't the plugin, Adjustments>Hue/Saturation and pull the Hue slider to the extreme left or the extreme right, then Invert Colors) and set the obtained layer to Multiply/Color Burn. Quote http://synthastic.deviantart.com http://soundcloud.com/siderealenterprise Lockerz invites are available, PM me Link to post Share on other sites
himself22 1 Posted July 25, 2009 Report Share Posted July 25, 2009 wow guys, I was kidding, here's a serious tip: when your board and have no ideas, download a plugin you don't already have and make an image either from scratch or using a stock, but base it around that plugin. like this: I didn't really change this a lot but I learned what it does. Oh, another tip, when you download a plugin, see if it was based off a tutorial, a little example, gradients, I had no idea how to make one before I saw the tutorial, and if you need a weird gradient shape Paint.Net when you read the tutorial, you can make your own shapes like this: Quote "The truth is just an excuse for having a lack of imagination." Photobucket sucks! Link to post Share on other sites
yy10 5 Posted July 29, 2009 Report Share Posted July 29, 2009 when you finished an image but you still think you should add something think you can do this: (sorry no screenshots) 1. if your image has lots of layers, then flatten it 2. duplicate image 3. on the duplicated image, do a zoom blur(effects>blur>zoom blur). full settings 4. make dat layer darken or lgihten by pressing F4 on ur keyboard try it. Quote deviantART sigs n stuff Link to post Share on other sites
Goonfella 220 Posted July 29, 2009 Report Share Posted July 29, 2009 If you want to keep/use only 2 or 3 layers in a multi layered picture without losing the entire PDN file, uncheck the ones you don`t want, flatten, save or copy the image depending on your needs, then just undo the process. :wink: Quote Please feel free to visit my Gallery on PDNFans And my Alternatives to PDN Link to post Share on other sites
Gamer_World14 1 Posted July 29, 2009 Report Share Posted July 29, 2009 If you want to keep/use only 2 or 3 layers in a multi layered picture without losing the entire PDN file, uncheck the ones you don`t want, flatten, save or copy the image depending on your needs, then just undo the process. :wink:Yeah, I have done that one before, and it works well. Quote deviantART | Paint.NET Gallery | bennettfrazier.com <-- (My new Website!) Link to post Share on other sites
Axle 0 Posted August 26, 2009 Report Share Posted August 26, 2009 i do that a lot especially when i make animated .gif's Quote My Deviant Art | My Gallery Link to post Share on other sites
Jayed 0 Posted August 30, 2009 Report Share Posted August 30, 2009 As far as custom brushes on a separate layer, that`s something I always do. If you find you don`t want the effect anymore you can just delete the layer. no i was meaning on a new canvas so that you can use the brush at it' s full size. Hmm. I always did it slightly differently... O___o' 1) flatten image. 2) use the brush thing on the flattened image. Get it to what you like. click Ok. 3) undo until you have all your layers again. 4) make a new layer 5) ctl+f Quote Power comes to those who least expect it, Ambition comes to those who want it. Sometimes Ambition rules the Powerful, many times Ambition Is Power. Remember that Frodo, that ring could have been yours! Link to post Share on other sites
Jayed 0 Posted September 6, 2009 Report Share Posted September 6, 2009 Hi all forum members..Regards, Ireena The spam thread is the off topic section. Post there if you want to spam. If you have a tip for pdn by all means share here "I am a spammer!" does not qualify for a tip according to Rick... :? Quote Power comes to those who least expect it, Ambition comes to those who want it. Sometimes Ambition rules the Powerful, many times Ambition Is Power. Remember that Frodo, that ring could have been yours! Link to post Share on other sites
Simon Brown 44 Posted September 6, 2009 Report Share Posted September 6, 2009 The crash dialog isn't modal, so nothing stops you saving your changes before you click OK and PDN closes. Quote Link to post Share on other sites
