jakob Posted October 30, 2007 Share Posted October 30, 2007 hi, jus wanna know whether theres noise filter plug-in?? thanks Quote Link to comment Share on other sites More sharing options...
barkbark00 Posted October 30, 2007 Share Posted October 30, 2007 There is a noise effect available with the base download... In Paint.NET go to Effects>Noise. Quote Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
jakob Posted October 30, 2007 Author Share Posted October 30, 2007 err.. as in, a plug-in to REDUCE or REMOVE noise.. Quote Link to comment Share on other sites More sharing options...
SSPhoto Posted October 30, 2007 Share Posted October 30, 2007 Most noise reducers are done by simply smoothing out and image with JPG Artifact removal being the exception. So to "denoise" an image in Paint.net I would use "Soften Portrait" effect then possibly adjust with "Curves" (down) using luminance. Quote eric Link to comment Share on other sites More sharing options...
Crazy Man Dan Posted October 30, 2007 Share Posted October 30, 2007 There was a handy Beta plugin for noise removal based off the GREYCstoration noise removal algorithm. Unfortunately, in the spam attack on the old forum and the subsequent move, the thread was lost. I've taken the liberty of mirroring the plugin on my site since it seems like the creator does not intend to return. If you wish to give it a try, the ZIP is here: http://cmdsketchpad.com/pdn/GREYCstoration_pdn.zip Both the DLL and the EXE go in the Effects folder, and the command prompt window popping up is normal. The EXE is actually the GREYCstoration program itself, and it uses the command line interface to function. The DLL serves as the interface between PDN and the GREYC program, passing the current layer and the necessary parameters to the program in the way the program expects to run the noise cancellation on that layer. Quote I am not a mechanism, I am part of the resistance; I am an organism, an animal, a creature, I am a beast. ~ Becoming the Archetype Link to comment Share on other sites More sharing options...
Blooper Posted October 30, 2007 Share Posted October 30, 2007 Remember, that plugin's very buggy. It doesn't work very well if you have alpha in your image, and it can crash PDN. So remember to save before you use it! Quote http://synthastic.deviantart.com http://soundcloud.com/siderealenterprise Lockerz invites are available, PM me Link to comment Share on other sites More sharing options...
usedHONDA Posted October 30, 2007 Share Posted October 30, 2007 And if possible, resize your image to shorten loading times. An 8MP picture can take over a full minute just to preview your image. Quote "The greatest thing about the Internet is that you can write anything you want and give it a false source." ~Ezra Pound twtr | dA | tmblr | yt | fb Link to comment Share on other sites More sharing options...
Ash Posted October 30, 2007 Share Posted October 30, 2007 Aside from what CMD said, soometimes you can use "surface blur" too. Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 31, 2007 Share Posted October 31, 2007 You can also use Effects->Blur->Median and set it to "1". That is how most programs implement their basic "Remove Noise" filter. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
The_Lionhearted Posted October 31, 2007 Share Posted October 31, 2007 Apparently there's a million different ways to skin a cat...I use me a little Surface blur. Quote My Gallery Link to comment Share on other sites More sharing options...
Crazy Man Dan Posted October 31, 2007 Share Posted October 31, 2007 Remember, that plugin's very buggy. It doesn't work very well if you have alpha in your image, and it can crash PDN. So remember to save before you use it! Note that the plugin has never crashed for me except when doing the one thing against which the plugin author cautioned - closing the command prompt window while the effect was running. As long as you let the algorithm finish its work, you should be fine. :wink: Quote I am not a mechanism, I am part of the resistance; I am an organism, an animal, a creature, I am a beast. ~ Becoming the Archetype Link to comment Share on other sites More sharing options...
Blooper Posted October 31, 2007 Share Posted October 31, 2007 Remember, that plugin's very buggy. It doesn't work very well if you have alpha in your image, and it can crash PDN. So remember to save before you use it! Note that the plugin has never crashed for me except when doing the one thing against which the plugin author cautioned - closing the command prompt window while the effect was running. As long as you let the algorithm finish its work, you should be fine. :wink: Never for me either. But apparently, it has a big propensity (maybe depending upon how complicated the selection is) to crash PDN. [edit] After tests, it can get very slow. Enough for me to eat some three-cheese lasagna. Quote http://synthastic.deviantart.com http://soundcloud.com/siderealenterprise Lockerz invites are available, PM me Link to comment Share on other sites More sharing options...
david.atwell Posted October 31, 2007 Share Posted October 31, 2007 It's never crashed on me, either. Darn slow, though. Quote The Doctor: There was a goblin, or a trickster, or a warrior... A nameless, terrible thing, soaked in the blood of a billion galaxies. The most feared being in all the cosmos. And nothing could stop it, or hold it, or reason with it. One day it would just drop out of the sky and tear down your world.Amy: But how did it end up in there?The Doctor: You know fairy tales. A good wizard tricked it.River Song: I hate good wizards in fairy tales; they always turn out to be him. Link to comment Share on other sites More sharing options...
Crazy Man Dan Posted October 31, 2007 Share Posted October 31, 2007 Hey! It's performing weighted anisotropic smoothing! Give it a break. I'd like to see you do that faster... Quote I am not a mechanism, I am part of the resistance; I am an organism, an animal, a creature, I am a beast. ~ Becoming the Archetype Link to comment Share on other sites More sharing options...
david.atwell Posted October 31, 2007 Share Posted October 31, 2007 Sure! Give me a calculator, and I'll get right on it. Quote The Doctor: There was a goblin, or a trickster, or a warrior... A nameless, terrible thing, soaked in the blood of a billion galaxies. The most feared being in all the cosmos. And nothing could stop it, or hold it, or reason with it. One day it would just drop out of the sky and tear down your world.Amy: But how did it end up in there?The Doctor: You know fairy tales. A good wizard tricked it.River Song: I hate good wizards in fairy tales; they always turn out to be him. Link to comment Share on other sites More sharing options...
