BubbaGee Posted October 19, 2007 Share Posted October 19, 2007 I've looked all around and I can't find any way to change the default 24-bit color images (*.bmp) to 8-bit. The reason for doing this is because I'm trying to generate sample images for a program that does pattern matching and it only accepts 8-bit color images. Is it possible with Paint.NET and I just didn't see it. Thanks, BubbaGee Quote Link to comment Share on other sites More sharing options...
Myrddin Posted October 19, 2007 Share Posted October 19, 2007 A quick search would have resulted this: On the same matter[/url], BoltBait":44091]Everything Paint.NET does is in 32 bit. Currently, the only way to convert your picture to 8 bit is to save it in GIF format.If you want to save it in 24 bit, just select BMP format. Rick has said that 8 bit BMP format is coming. Does this answer you? Quote How to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
BubbaGee Posted October 19, 2007 Author Share Posted October 19, 2007 I did do a search using '8-bit' and 'reduce color' and never saw that one. Thanks for the reply and the information. Thanks, BubbaGee Quote Link to comment Share on other sites More sharing options...
david.atwell Posted October 19, 2007 Share Posted October 19, 2007 Yeah, search has been doing weird stuff recently. You're not the only one to miss something like that. :-) Quote The Doctor: There was a goblin, or a trickster, or a warrior... A nameless, terrible thing, soaked in the blood of a billion galaxies. The most feared being in all the cosmos. And nothing could stop it, or hold it, or reason with it. One day it would just drop out of the sky and tear down your world.Amy: But how did it end up in there?The Doctor: You know fairy tales. A good wizard tricked it.River Song: I hate good wizards in fairy tales; they always turn out to be him. Link to comment Share on other sites More sharing options...
