Gradient Mapping
pyrochild
Thank you @NN, @BB and @Pyro for your assistance :pizza::beer::cake: .
I gave up, after hours of trying to 'weed-out' plugins to make sure they were current, and took @BB's advice and  deleted the whole lot!  I now have 3 plugins:
Gradient Mapping, Liquify and Smudge.  Happily Gradient Mapping is now working.  I will watch what I add now, like a hawk, and hope the problem does not re-occur.
So in effect, I'm kind of naked now in the Effects folder emoticon-cute-002.gif
OK - it's Imgur Uploader that is making Gradient Mapping go awry.  As soon as I inserted it into Effects, it causes the same problem to happen.  Do I need to post this  in the Imgur Uploader thread?  I have checked and have used his latest version.  Strange thing is that it's still working fine on my lap top :roll: .  This is so frustrating as I use Imgur Upload a lot and also Gradient Mapping.  Grrrrrrrrrrrrrrrr :/
Imgur Uploader was recently updated. Did you download the newest version?
Yes @EER - am using the recent version and it's working - only thing is, on my HP computer, it's clashing with Gradient Mapping.  Not so on my laptop which is not HP :roll:
Thanks @Pyro - I tried it and it works fine without Imgur.  Once Imgur is added to the Effects folder, it crashes again.  But, Imgur is working fine and I actually used it to show you
the crash below.
http://i.imgur.com/QjdzUyN.png
  • 1 year later...
  • 8 months later...
Update!
  • New: saving a preset includes all settings in the dialog
  • Fix ArgumentOutOfRangeException when getting too wild with the gradient handles
  • Fix crash on loading a bad file
  • Fix transparent color if nodes overlap
  • Fix: Default preset would sometimes remember changes made while it was active
  • Fix crash if spread or reverse functions are used with 1 or 0 colors
Installer:
  • New: now supports installing plugins for Window Store version of paint.net
  • New: add option to start paint.net after successful installation
  • Like 2
  • Upvote 2
ambigram signature by Kemaru
[i write plugins and stuff]
  • 1 year later...
Hello @pyrochild I have noticed that since v4.1.5 the Gradient Mapping is acting differently.
This is with v4.1.5:
https://ttprivatenew.s3.amazonaws.com/pulse/nalsop-live/attachments/11203235/TinyTake06-08-2019-02-09-15.mp4
And now it no longer keeps the Preserve Alpha box checked:
https://ttprivatenew.s3.amazonaws.com/pulse/nalsop-live/attachments/11203375/TinyTake06-08-2019-02-28-06.mp4
@Pixey, take a look at the xml file of your preset (in any text editor). In the line
<Gradient xmlns:xsd="http://www.w3.org/2001/XMLSchema" ... Offset="0" Wrap="true" LockAlpha="false">
replace LockAlpha="false" to LockAlpha="true"  and save this file.
Hi @ReMake thanks for your response.  I can't figure out how to "open" the .cs file.  I've gone to:
This PC -  Documents - Paint.net User Files - Effect Presets - Gradient Mapping - but all that's in there are the .xml's themselves 😲
I finally figured out how to open one of them 🤗 but I don't see the part where I can change it to LockAlpha="true"   All I see is this:
Replace line:
<Gradient xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
with line:
<Gradient xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" LockAlpha="true">
Note the space between the quotes and LockAlpha - it must be present.
