darkmelody Posted September 28, 2007 Share Posted September 28, 2007 I' m not sure if it's my computer or if it just suppose to be like that but when I use alpha with the paint brush it always turns out kind of blochy. it works quite well when I use alpha with the different shape and line drawers please tell me if this is suppose to happen and if it's not, how to fix it. Thanks Quote Link to comment Share on other sites More sharing options...
barkbark00 Posted September 28, 2007 Share Posted September 28, 2007 That is just a limitation of the current 'brush system'...no bug. Upgrades are planned for the future (4.xx?). Just check out the roadmap... Quote Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
Bob Posted September 28, 2007 Share Posted September 28, 2007 This is a known behaviour, there is nothing wrong on your side. Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to comment Share on other sites More sharing options...
BoltBait Posted September 28, 2007 Share Posted September 28, 2007 You can get around this issue by changing the paint brush blending mode to "overwrite". It is located at the end of the tool bar and looks like this: :OverwriteBlending: Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
usedHONDA Posted September 28, 2007 Share Posted September 28, 2007 Noooo! Never use Overwrite... ever! Unless the situation calls for. But in this case, it doesn't. Follow these steps: 1. Create a new layer 2. Make your brush strokes in full opacity (no alpha) 3. Go to Layer Properties and adjust the layer's Opacity from there It's the easiest (and almost the only) way to make perfect alpha valued brush strokes in Paint.NET. Quote "The greatest thing about the Internet is that you can write anything you want and give it a false source." ~Ezra Pound twtr | dA | tmblr | yt | fb Link to comment Share on other sites More sharing options...
darkmelody Posted September 29, 2007 Author Share Posted September 29, 2007 thanks for the help everyone! :wink: thankyou usedHONDA ^^ but I can't use this method because I mainly draw on Paint and I want to use alpha for shading Noooo! Never use Overwrite... ever! Unless the situation calls for. But in this case, it doesn't.Follow these steps: 1. Create a new layer 2. Make your brush strokes in full opacity (no alpha) 3. Go to Layer Properties and adjust the layer's Opacity from there It's the easiest (and almost the only) way to make perfect alpha valued brush strokes in Paint.NET. Quote Link to comment Share on other sites More sharing options...
david.atwell Posted September 29, 2007 Share Posted September 29, 2007 thanks for the help everyone! :wink: thankyou usedHONDA ^^ but I can't use this method because I mainly draw on Paint and I want to use alpha for shading What do you mean? You can do it that way, it would work just fine. Unless I'm misunderstanding... Quote The Doctor: There was a goblin, or a trickster, or a warrior... A nameless, terrible thing, soaked in the blood of a billion galaxies. The most feared being in all the cosmos. And nothing could stop it, or hold it, or reason with it. One day it would just drop out of the sky and tear down your world.Amy: But how did it end up in there?The Doctor: You know fairy tales. A good wizard tricked it.River Song: I hate good wizards in fairy tales; they always turn out to be him. Link to comment Share on other sites More sharing options...
