Sir Hugh Posted September 23, 2007 Share Posted September 23, 2007 Hello everyone, I'm relatively new to image edditing.I have used the GIMP a bit, but I like the ease of use of PDN. This post is basically asking how to change the colors in an image based on its shading. I would like to change the color of a this navigation banner from red to green without having to start all over, but while keeping its current look. Any help is appreciated. Sir Hugh Quote Link to comment Share on other sites More sharing options...
MattBlackLamb Posted September 23, 2007 Share Posted September 23, 2007 Search the plugin forum for "Conditional Hue & saturation Adjusment" That's what you need Quote dA Son, someday you will make a girl happy for a short period of time. Then she'll leave you & be with men that are ten times better than you can imagine. These men are called musicians. Link to comment Share on other sites More sharing options...
Sir Hugh Posted September 23, 2007 Author Share Posted September 23, 2007 Thanks, I had to get the terminology right. I found a Conditional Hue/Saturation plugin that worked out nicely. Quote Link to comment Share on other sites More sharing options...
MattBlackLamb Posted September 23, 2007 Share Posted September 23, 2007 You're welcome, glad to help Quote dA Son, someday you will make a girl happy for a short period of time. Then she'll leave you & be with men that are ten times better than you can imagine. These men are called musicians. Link to comment Share on other sites More sharing options...
Helio Posted September 23, 2007 Share Posted September 23, 2007 Actually, if you just want to change the hue of the whole image, the built-in Hue adjustment feature should work nicely for you, Sir Hugh! Adjustments > Hue/Saturation... OR (Ctrl)-(Shift)-(U). -Top slider adjusts hue. -Middle slider adjusts saturation. -Bottom slider adjusts lightness. Quote v An excellent open–source strategy game—highly recommended. "I wish I had never been born," she said. "What are we born for?" "For infinite happiness," said the Spirit. "You can step out into it at any moment..." Link to comment Share on other sites More sharing options...
