rolandd Posted December 20, 2005 Share Posted December 20, 2005 Hello, First, the program looks very neat with the .NET 2.0 Framework Second, in previous versions and now also in the latest one, 2.6 alpha 2, I experience a crash when I want to get an image from my scanner. The scanner is a HP Scanjet 4300C. Here is the crashlog: Crash log for Paint.NET v2.6 (Alpha 1 Release build 2.6.2172.1929) Time of crash: 20-12-2005 11:32:36 OS version: 5.1.2600.131072 .NET Framework version: 2.0.50727.42 X86 Processor count: 1 Exception details: System.IO.FileNotFoundException: C:\Documents and Settings\Roland\Local Settings\Application Data\Paint.NET\1234159418\611607471.bmp at System.Drawing.Image.FromFile(String filename, Boolean useEmbeddedColorManagement) at System.Drawing.Image.FromFile(String filename) at PaintDotNet.MainForm.menuFileAcquireFromScannerOrCamera_Click(Object sender, EventArgs e) at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e) at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e) at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ToolStrip.WndProc(Message& m) at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ------------------------------------------------------------------------------ Crash log for Paint.NET v2.6 (Alpha 1 Release build 2.6.2172.1929) Time of crash: 20-12-2005 11:33:13 OS version: 5.1.2600.131072 .NET Framework version: 2.0.50727.42 X86 Processor count: 1 Exception details: System.IO.FileNotFoundException: C:\Documents and Settings\Roland\Local Settings\Application Data\Paint.NET\636068314\574102537.bmp at System.Drawing.Image.FromFile(String filename, Boolean useEmbeddedColorManagement) at System.Drawing.Image.FromFile(String filename) at PaintDotNet.MainForm.menuFileAcquireFromScannerOrCamera_Click(Object sender, EventArgs e) at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e) at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e) at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ToolStrip.WndProc(Message& m) at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ------------------------------------------------------------------------------ Crash log for Paint.NET v2.6 (Alpha 2 Release build 2.6.2179.30797) Time of crash: 20-12-2005 11:41:46 OS version: 5.1.2600.131072 .NET Framework version: 2.0.50727.42 X86 Processor count: 1 Exception details: System.IO.FileNotFoundException: C:\Documents and Settings\Roland\Local Settings\Application Data\Paint.NET\1343316540\1404929147.bmp at System.Drawing.Image.FromFile(String filename, Boolean useEmbeddedColorManagement) at System.Drawing.Image.FromFile(String filename) at PaintDotNet.MainForm.menuFileAcquireFromScannerOrCamera_Click(Object sender, EventArgs e) at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e) at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e) at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ToolStrip.WndProc(Message& m) at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ------------------------------------------------------------------------------ Hope you can help Regards, RolandD Quote Link to comment Share on other sites More sharing options...
