sfchains 0 Posted December 20, 2005 Report Share Posted December 20, 2005 I have been using Paint.net for a few weeks now and can not stop telling all my friends they need to start to use it. I have been doing fairly basic things up to now and this evening I was 'superimposing' some friends face pictures into various scenery shots by using 2 layers. I got the results I wanted in the new file, but at a later time when I displayed all of the files I have using Windows Explorer, the 'merged picture' file has a thumbnail of one of the originals that I used rather than being a thumbnail of itself. When I open the file it correctly displays the 'merged picture' This only happens if I save the files as a .jpg. If I save it as a .pdn, the thumbail is correct. I have tried reversing the order I bring the 2 files in and I have the "Do Not Cache Thumbnails" turned on. Any advice or suggestions will be greatly appreciated. Quote Link to post Share on other sites
Crazy Man Dan 19 Posted December 20, 2005 Report Share Posted December 20, 2005 Hmm, I can't get this to happen... What version of Paint.NET are you using? 2.5 Final? Also, the images you bring in, are they both .jpg images which you combine and save as a .jpg? Do you have a way of posting a screenshot of the errant thumbnail and the thumbnail how it's supposed to look? Quote I am not a mechanism, I am part of the resistance; I am an organism, an animal, a creature, I am a beast. ~ Becoming the Archetype Link to post Share on other sites
Rick Brewster 1,757 Posted December 20, 2005 Report Share Posted December 20, 2005 I can't follow the timeline on this either ... could you post a list of specific instructions to get this to repro? Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
sfchains 0 Posted December 21, 2005 Author Report Share Posted December 21, 2005 Thank you for looking at my problem. When I do HELP/ABOUT it displays Version 2.5. I have solved the issue but I am not sure if I have found a bug in Paint.net or if it is a Windows'ism! If you start by opening Paint.net comared to opening the first file, when you save your 'merged' picture to a new file the thumbnail is correct. If you start by opening the first file you are going to use (which is what I was doing), when you save the 'merged' picture to a new file, the thumnail is that of the first file. If you then right click the new file name and select Refresh Thumbnail then everything is correct. I assumed a thumbnail was 'refreshed' anytime a file was written/updated and that is not the case in the second method above. Again, thank you for looking at my posting. Quote Link to post Share on other sites
