Installation Problem.
Right, I signed up just to ask this, I really want Paint.NET
Whenever I load the installer (the only file in the .zip) it always comes up with this error:
I have redownloaded twice, twice of main mirrior and once of a alternate mirrior.
Does anyone know what is causing this problem?
More specifically, it's the .NET framework v3.0, if you were confused.
What the...? We weren't flaming...
Let's see...
You should try extracting the installer to the desktop if you haven't already. I'm not sure if the installation would work right from the zip. Also make sure you have the .NET Framework 2.0 or 3.0 installed. If it still doesn't work, read this thread:
PROBLEMS WITH INSTALL UPDATE OR UNINSTALL? READ THIS.
Also, you should redefine what you call flaming. I don't see anything rude about what they were saying. After all, they're here to help you, not announce that your an idiot (of which you are not) as you may be thinking.
"The greatest thing about the Internet is that you can write anything you want and give it a false source." ~Ezra Pound
twtr | dA | tmblr | yt | fb
