Anti-alias Plugin [v1.5.8.0 Minor fixes, August 25th, 2007]
I love this plugin but it crashes when messing around with the settings on small images.
  • This text file was created because Paint.NET crashed.
    Please e-mail this file to
paint.net@hotmail.com so we can diagnose and fix the problem.
Application version: Paint.NET v3.10 (Final Release build 3.10.2791.35943)
Time of crash: 10/1/2007 9:23:45 PM
Application uptime: 00:00:41.5790000
OS Version: 6.0.6000.0 Workstation x86
.NET Framework version: 2.0.50727.312 x86
Processor: 2x "AMD Athlon 64 X2 Dual Core Processor 3800+" @ ~2003MHz (DEP, SSE, SSE2, SSE3)
Physical memory: 2045 MB
Tablet PC: no
Exception details:
PaintDotNet.WorkerThreadException: Worker thread threw an exception ---> System.ArgumentOutOfRangeException: Coordinates out of range, max={Width=14, Height=14}
Parameter name: (x,y)
Actual value was {X=-8,Y=-8}.
at PaintDotNet.Surface.get_Item(Int32 x, Int32 y)
at PaintDotNet.Effects.UserScript.getAveragePixel(Int32 x, Int32 y, Surface src, Rectangle selection)
at PaintDotNet.Effects.UserScript.Render(Surface dst, Surface src, Rectangle rect)
at PaintDotNet.Effects.UserScript.Render(EffectConfigToken parameters, RenderArgs dstArgs, RenderArgs srcArgs, Rectangle[] rois, Int32 startIndex, Int32 length)
at PaintDotNet.Effects.BackgroundEffectRenderer.RendererContext.RenderImpl()
at PaintDotNet.Effects.BackgroundEffectRenderer.Join()
at PaintDotNet.Effects.BackgroundEffectRenderer.Start()
at PaintDotNet.Menus.EffectMenuBase.EffectConfigTokenChangedHandler(Object sender, EventArgs e)
at PaintDotNet.Effects.EffectConfigDialog.OnEffectTokenChanged()
at PaintDotNet.Effects.TwoAmountsConfigDialogBase.amount1Slider_ValueChanged(Object sender, EventArgs e)
at System.Windows.Forms.TrackBar.OnValueChanged(EventArgs e)
at System.Windows.Forms.TrackBar.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
Do ya think that you could make it into a downloadable file? Because I'm not all up with all the coding & stuff... but this plugin sounds sweet. I mostly like just messin with pics and stuff, but yeah.
If you could do that, or tell me how to make it into a file equivalent to the ones that are downloadable... that'd be great.
Thx. =]
It already is. On the first page, first post and underneath the last picture of the cat you will see a line beginning with 'dll', the accompanying link is the downloadable file.
The source code is there for anyone wishing to take a look at the inner-workings of the plugin and/or advance that for their own personal gain - this is great of example of the term 'open source': the source is open for anyone and everyone.
  • 3 months later...
  • 3 weeks later...
  • 6 months later...
  • 3 years later...
Author hasn't been on the forum for over a year :(
solution #1: Load the provided source file into Codelab & build it.
solution #2: Use an alternative
solution #3: Ask friendly Mod to fix the problem ;)
I've recompiled the source and appended the dll to the first post - removing the broken link. Enjoy.
  • 2 years later...
  • toe_head2001 changed the title to Anti-alias Plugin [v1.5.8.0 Minor fixes, August 25th, 2007]
  • 1 year later...
