What the ... ? (installing problem)
Edited by Rick: Changed title to remove profanity
Recently I had a slight computer problem but I got it fixed and when I ran paint.net, my comp couldn't find it, I figured it was no biggie cause all my data was saved on a separate file and I could just reinstall it, but it begins to install the following comes up :
There is a problem with this windows installer package. A program required for this install to complete could not be run. Contact your support personnel or package vendor.
Tell me if you know ANY way short of reinstalling the OS system I can fix this hell, thanks man.
Two things:
1) Don't cuss in your thread title. If you ever do this again you will be banned.
2) http://paintdotnet.12.forumer.com/viewtopic.php?t=854 ... c'mon. It's right at the top of the forum in big huge capital letters. It will solve your problem.
Thread Closed
