Rick Brewster Posted December 6, 2005 Share Posted December 6, 2005 You can limit drawing to a specific region simply by selecting it, and then drawing. "Drawing" includes effects. So if you only want to blur some rectangular region then select it with the Rectangle Select tool and then do the blur. 1. I'm not sure what you mean by "reversed." There is unlimited undo/history, but we have not implemented any of those algorithms that have been developed for the purpose of un-blurring or doing various levels of noise reduction or enhancement. Probably because they're mind bogglingly complex. They also require a lot of processing time (although this will be helped by the trend towards 64-bit and multicore computing). 2. I don't understand what you mean by this. 3. There is no tool for doing this. We've talked about ways to implement this but it'd be a long ways off in any event. 4. Paint.NET is not an animation program, and we will not be doing this. 5. No, we will not be adding this to Paint.NET. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
