leandro_tami Posted July 19, 2007 Share Posted July 19, 2007 Hi. I'm having problems when I define very small selection areas (ex. 8x8) and then try to move it by using the move selection tool. I click inside the selection area but instead of moving what I get is resizing. Quote Link to comment Share on other sites More sharing options...
HITMAN-X- Posted July 19, 2007 Share Posted July 19, 2007 using the move selection tool on small selections works better if you move the move selection tool out of the 8x8 you selected and then draged. It will still move the selection even if your not in the box you selected. Quote DEXTUT.COM Link to comment Share on other sites More sharing options...
TakeMangaka Posted July 27, 2007 Share Posted July 27, 2007 Yeah. As long as you see the "arrow" cursor, then you'll know that what's selected is the wanted area. Quote I'm BRAZILIAN! I love Anime Art! Link to comment Share on other sites More sharing options...
egofree Posted August 11, 2007 Share Posted August 11, 2007 I have the same problem. I have a small image (16x16) and i don't manage to use the 'move selected pixels' tool inside this image. If i move the cursor to the center of the selection or outside the selection, i never get the arrow cursor. I have only the hand cursor. Quote Link to comment Share on other sites More sharing options...
egofree Posted August 11, 2007 Share Posted August 11, 2007 I have done more tests. With my 16x16 image, the selection must be at least 14x14 pixels in order to get an arrow cursor inside the selection. For smaller selections, i have to put the cursor outside the drawing area. Quote Link to comment Share on other sites More sharing options...
