having problems
okay i'm having problem downloading paint.net it says somethiing about a packager or something, it says that it had a problem with a program and that i should turn windows features on or off
i don't get it can anyone help me fix this?
i downloaded it fine the first time it worked great and i loved it but something happenend and i couldn't use it anymore so i uninstalled and installed it but it started saying that i downlaod dot net but it really don't think it's helping
so can anyone help me
sorry for my bad spelling
i tried it says it's already part of the operating system
so i was really happy like yeah now i can you paint.net again but when i tried to download paint it says "there is a problem with this Windows intaller package. A program required for this install to complete could not be run. Contact you support personnel or package vendor" then it says a fatal error during installation.
so can anyone please help me because i really enjoyed using the program and it's easier and free,compared to photoshop.
so please need help that will work
will i checked that out and i installed the version 3 thing and it says requirements not met so wts up with that?
also the 2.0 version of the dot net thing says it's part of the operating system yet i cant find it in the control panel oh yeah i have vista maybe that's that problem? but yeah i'm not sure it worked the first time now i just dont get what the hell is going on it's really making me mad:evil:
and oh yeah i'm trying to download the new version of paint.dot ne 3.08 and another thing the older version 3.05 is on my system and can't uninstall it because i don't have dot net framework and i can't install it so how and what i'm i supposed do
Yeah, sorry, the .NET Framework is bundled with Vista, so you don't have to install it.
Is Paint.NET still in the 'Add or Remove Programs' list?
(or its Vista's equivalent)
No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio
yeah but it cant be deleted it says something about the installer package or vender, i'm not sure but it says something about turning on or off features but so i turned off some feature that were related to dot net thing but it's still not working makes no sense to
ps thank you for helping man
yeah i know i checked that it's there but i when i try to download paint it says a program needed to finish download couldn't be run, so i really don't get that any ideas to what's wrong?
So...do you get the error while you're downloading, or at the end of actually installing it?
Screenshots might be helpful, too.
this thing keeps coming when i try to download it at the end just before it can be downloaded and when i try to delete the older version of paint from my computer i really dont get why it comes up and it would be really helpfully if the stupid thing would tell me what file is missing so i can get it instead say that bull
wow still no help this sure was helpfully :cry:
