Fix: Building Paint.Net when directory contains spaces
Problem: If you copy Paint.Net project into a directory and attempt to build it you will get errors. Example:
C:\\Documents and Settings\\Administrator\\Desktop\\
These errors come from the Paint.Net project properties with post build commands.
Fix: Go into the embedManifest.bat file and remove all quotes. The file should look like....
mt.exe -nologo -manifest %2 %3 %4 -outputresource:%1
Chris
