Ruck Posted June 19, 2007 Share Posted June 19, 2007 Hi everyone, I'm new, love the tips on the forum. I'm not sure what the effect is called, but i basicall want to change the guy in this photo to something like the bit on the right, ignore the t-shirt part, i was too lazy to cut it from the image. all help appreciated Ruck Quote Link to comment Share on other sites More sharing options...
barkbark00 Posted June 19, 2007 Share Posted June 19, 2007 This is done by desaturating(Ctrl+Sft+G) the image and then adjusting the the contrast(Ctrl+Sft+C) to about 95-100. Also try playing with the brightness level to get your desired detail... I was gonna make him bald... Quote Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
Crazy Man Dan Posted June 19, 2007 Share Posted June 19, 2007 Alrighty, here's one way to do it: Step 1: Select Colors -> Black & White Step 2: Trace the outline of the player with the Line / Curve tool with Black as your primary color. If desired, you can create a new layer and draw there. Step 3: Fill in the outside areas with Black using the Paintbrush tool. The anti-aliased edges are often hard to get with both the Magic Wand and the Paintbucket, so the Paintbrush is recommended here. Set the brush width large for the larger areas, then shrink it to get the details. Merge the two layers when complete if you chose to use a second layer. Step 4: Open Brightness / Contrast. Set the Contrast to 100 and adjust Brightness until you get your desired result. Hope that helps! Quote I am not a mechanism, I am part of the resistance; I am an organism, an animal, a creature, I am a beast. ~ Becoming the Archetype Link to comment Share on other sites More sharing options...
Akkarins_Spirit Posted June 19, 2007 Share Posted June 19, 2007 Hey Ruck, you might know me as Drahcir. Anyway, if it's something like this: Cut out the image heres a link to the tutorial: http://paintdotnet.12.forumer.com/viewtopic.php?t=5276 Then go to adjustments and select Brightness/Contrast:BrightnessContrast: Move contrast to 100 and adjust the brightness to suit the picture EDIT: bloody potato, ye got there before me Quote I'm not a fan-boy, i have ALL 3 of the consoles.........PS,PS2 and PS3 Link to comment Share on other sites More sharing options...
The_Lionhearted Posted June 19, 2007 Share Posted June 19, 2007 Hey Ruck, you might know me as Drahcir. Cool...another Richard. Quote My Gallery Link to comment Share on other sites More sharing options...
Ruck Posted June 19, 2007 Author Share Posted June 19, 2007 Hey Ruck, you might know me as Drahcir. Cool...another Richard. that makes three. thanks for the help everyone. Quote Link to comment Share on other sites More sharing options...
Ruck Posted June 19, 2007 Author Share Posted June 19, 2007 and here's a result using another pic. thanks guys Quote Link to comment Share on other sites More sharing options...
barkbark00 Posted June 19, 2007 Share Posted June 19, 2007 Here are a few others I made while messing around... Quote Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
Nesk Posted June 19, 2007 Share Posted June 19, 2007 Wow, those look cool, barkbark00! Quote Link to comment Share on other sites More sharing options...
Ruck Posted June 24, 2007 Author Share Posted June 24, 2007 cool! how did you do those? Quote Link to comment Share on other sites More sharing options...
barkbark00 Posted June 25, 2007 Share Posted June 25, 2007 it was something similar to this... http://paintdotnet.12.forumer.com/viewt ... ch++pencil Quote Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
