I need help. I must be doing something wrong.
I have been doing stuff that you guys have tought on this forum. I tried everything on this forum. I think? I can't get a picture fade into nothing using a gif animater. The ending result is a white left over of the picture on my desktop. Any ideas! please. Tried and tried and......
If you want a smooth fade, it's impossible.
GIF just support yes/no transparency.
If you don't understand, i clearly apologize, but heh, it's 01AM here.
No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio
Sorry. I Used majic wand on PDN and saved it as .ping or gif. then I transfered it to a gif animater manialy fade it or use the tween to do so. same outcome.
doesn't matter what you did *before* gif animator.
Once you change an image to gif format, there is no gradual fade to transparent, it's either fully transparent or fully opaque.
PNG supports variable transparency, but not animation.
