corsur Posted June 14, 2007 Share Posted June 14, 2007 Hello can anyone please tell me the easy way to put say 4 photos in the one photo frame, doesn't mater if the have to be sized down to do this just will be happy if i can get multiple pictures in one photo thanks Corsur. Quote Link to comment Share on other sites More sharing options...
Myrddin Posted June 14, 2007 Share Posted June 14, 2007 Image > Canvas size, resize to a really large dimension. Create a new layer then Layers > Import from file. Use the move selection pixel tool () and arrange where you want it. Do that for every picture. Create new layer... Once happy, use the square selection tool and draw a box around all the four images, the press Ctrl + Shift + X to crop the image to that selection. Save. Hope this helps. Quote How to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
Yata Posted June 14, 2007 Share Posted June 14, 2007 Also, read this. Read them all, but have a look at #4. Quote "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former" [ dA Paint.NET Chat :: Yata on dA ] Link to comment Share on other sites More sharing options...
corsur Posted June 14, 2007 Author Share Posted June 14, 2007 Thanks for that help, I have been wanting/trying to do that for ages. Quote Link to comment Share on other sites More sharing options...
