Dotti_Rose Posted June 8, 2007 Author Share Posted June 8, 2007 Ok ...I kinda have an ideal how they work. But I notice if I add one of the plug in's into my effects folder ' if I want to add a new plug in I cannot because it is written by the same publisher ...is there anyway around that? Second questions is there a plug in ....filler for like masks,starbrusts and effects like that? Quote I was born in a world of darkness seeking the light... Link to comment Share on other sites More sharing options...
Dotti_Rose Posted June 8, 2007 Share Posted June 8, 2007 Ok ...I kinda have an ideal how they work. But I notice if I add one of the plug in's into my effects folder ' if I want to add a new plug in I cannot because it is written by the same publisher ...is there anyway around that? Second questions is there a plug in ....filler for like masks,starbrusts and effects like that? Quote I was born in a world of darkness seeking the light... Link to comment Share on other sites More sharing options...
Yata Posted June 8, 2007 Share Posted June 8, 2007 Doti, your avatar is way to big, size is 100x500 at most. For your questions, I'm unsure what your asking, can you elaborate more? Quote "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former" [ dA Paint.NET Chat :: Yata on dA ] Link to comment Share on other sites More sharing options...
BoltBait Posted June 8, 2007 Share Posted June 8, 2007 Welcome to the forum. First, your avatar is way too wide, please fix. Second, just place the .dll file into your c:/program files/Paint.NET/Effects folder and your effects should show up in the Effects menu (or submenu under Effects). This page may help you http://boltbait.googlepages.com/install Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
spike 121 Posted June 8, 2007 Share Posted June 8, 2007 if i get your question, just rename the file Quote "No. Dreaming is illegal."~Pyrochild Link to comment Share on other sites More sharing options...
Dotti_Rose Posted June 9, 2007 Author Share Posted June 9, 2007 Thanks ...I did the renaming ... but I must be doing something else, wrong. It's still not taking so just downloaded 7-Zip so hopefully that will help me...to be able to put the plug in's in ... thanks for the help =) Quote I was born in a world of darkness seeking the light... Link to comment Share on other sites More sharing options...
Bob Posted June 9, 2007 Share Posted June 9, 2007 What was the original plugin name? Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to comment Share on other sites More sharing options...
Dotti_Rose Posted June 9, 2007 Author Share Posted June 9, 2007 OK Thank You for that Boltbait site ... that actually helped with a few of my files ... the unblocking ... Guess I should of read that ...a bit more ! Quote I was born in a world of darkness seeking the light... Link to comment Share on other sites More sharing options...
