tsts Posted November 16, 2005 Share Posted November 16, 2005 I found this programme while searching for a new graphic tool and I have spent the last 3 hours trying to get it to run. I downloaded 2 different installs and I run into the same issue when I try to get to the programme. My operating system is XP Home with SP2, and I have Microsoft.NET Framework v1.0.3705 and v1.1.4322 installed. I have tried to install the programme using PaintDotNet_2_5_RC1.exe and it tries to read my floppy drive, after which I get the following errors: SetupFrontEnd.exe - application has generated an exception that could not be handled. Process id=0x274(628), Thread id=0x74c(1868) I then click on "Cancel" to run the debug and get: No debugger found cordbg.exe !a 0x274 The install then stops. I installed the programme, it seems, using PaintDotNet_2_1b.msi, but when I click on the desktop icon to run the programme, it also tries to go to my floppy drive and then I get the following errors: PaintDotNet.exe - Common Language Runtime Debugging Services application has generated an exception that could not be handled. Process id=0x754(1876), Thread id=0xa50(2640) Clicking on "Cancel" gives me the same debug error. I cannot run the programme at all. Any help would be appreciated. Thank you Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 17, 2005 Share Posted November 17, 2005 Could you try uninstalling .NET 1.1, and then reinstalling it? I have seen this before when the .NET installation becomes corrupt somehow. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
tsts Posted November 17, 2005 Author Share Posted November 17, 2005 Thank you for the suggestion, but I have a slight problem with that. Even though .NET 1.1 is listed in the Add/Remove Software screen, there is no button there to remove it. I will see what I can do and let you know the result. Quote Link to comment Share on other sites More sharing options...
tsts Posted November 17, 2005 Author Share Posted November 17, 2005 The uninstall and reinstall seemed to do the trick, thank you once again. The programme now works. Quote Link to comment Share on other sites More sharing options...
