JLeigh Posted May 21, 2007 Share Posted May 21, 2007 Hi there! I am having a problem with the sepia function. The first time I used it was yesterday, and when I clicked "sepia", a box popped up that allowed me to customize the sepia look -as in what percentage. Today when I clicked "sepia", it just rendered the image as sepia without allowing me to customize the percentage. What am I doing wrong? Thanks! Link to comment Share on other sites More sharing options...
Ash Posted May 21, 2007 Share Posted May 21, 2007 Are you sure you use were using the same tool yesterday? All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
JLeigh Posted May 21, 2007 Author Share Posted May 21, 2007 Yes. It just "renders" the image as sepia without allowing me to customize it like I was able to yesterday. Link to comment Share on other sites More sharing options...
Ash Posted May 21, 2007 Share Posted May 21, 2007 I never see any adjustable windows for Sepia when I use it :? All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
JLeigh Posted May 21, 2007 Author Share Posted May 21, 2007 Really? I was so happy yesterday because I was able to choose the "percentage" of sepia, so my pic came out great. I hope I can figure this out.... Link to comment Share on other sites More sharing options...
Ash Posted May 21, 2007 Share Posted May 21, 2007 Color tint from a plugin...maybe? All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
JLeigh Posted May 21, 2007 Author Share Posted May 21, 2007 Nope. All I did was click sepia, and it gave me the ability to adjust it. Today it won't. In fact, when I look at the press release for my version, it lists "sepia adjustment" as a new feature: Paint.NET v2.5 Released: November 26th, 2005 - Download The major goals of this release were to improve performance, expand selection support to be much more useful and powerful, provide support for localization to other languages, and to have an easier way for users to have the latest version (update manager). Other features added include the ability to work with measurements in inches and centimeters, a 3D Rotate/Zoom effect, Sepia adjustment, Radial Blur and Add Noise effects, GIF transparency support, TGA file format support, file format plugin support, and a refined Text tool. What's new in Paint.NET v2.5? Faster performance and lower memory usage Full flexibility for scaling, rotating, and moving selections and selected pixels Ability to subtract from and add to selections Internationalization (I18N) support Officially available in German Line / Curve tool lets you draw spline and Bézier curves Ability to work in measurements of inches and centimeters 3D Rotate / Zoom effect lets you rotate, tilt, and tile images at various perspectives Radial Blur and Add Noise effects Sepia adjustment Improved Text Tool, including higher quality font rendering GIF transparency support TGA file format support Greater extensibility with a brand new File Format API Simpler, faster setup wizard Update manager simplifies getting the latest version Cleaner user interface with none of the annoying flickering of past releases Many other changes, improvements, and fixes Link to comment Share on other sites More sharing options...
Ash Posted May 21, 2007 Share Posted May 21, 2007 I hope you are not still using version 2.5 :shock: All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
Rick Brewster Posted May 21, 2007 Share Posted May 21, 2007 Sepia has never had a configuration dialog. If you are using v2.5, then you must upgrade to the latest version (3.07) -- otherwise we simply can't help you with anything here on the forum. (the rules, #5: http://paintdotnet.12.forumer.com/viewtopic.php?t=3446 ) The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
JLeigh Posted May 21, 2007 Author Share Posted May 21, 2007 Actually, it's the Version 2.5, 2.6x, 2.7x. I have no choice because I have win2k (cannot afford to upgrade, period) and the latest version is not compatible with win2k. Anyway, I'm still hoping I can figure out how to get my adjustment back. Link to comment Share on other sites More sharing options...
Rick Brewster Posted May 21, 2007 Share Posted May 21, 2007 Sorry man, like the rules say ... You may have inadvertenly clicked on an adjustment that was right next to Sepia. Maybe you had a plugin installed -- that's my best guess. Thread Closed The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
