Enormators Effects
Enormator
there are two problems with the lense flare thing:
1. I can't draw lines from up to down because... I don't know why I can't! These lines should be only one from the top to the point where they end and at their end they shouldn't begin again with white but stay black!
I have used alpha to grayscale on it to make it better viewable.
2. This is amazingly slow in rendering and I have no idea why.
   PdnRegion selectionRegion = EnvironmentParameters.GetSelection(src.Bounds);
 // Create a random number to initiate the reseed value
 int reseed = 0;
 Random randinit = new Random();
 if (reseed == 0) reseed = randinit.Next((int)(rect.Bottom * rect.Right + 1));
 // rand = Random number generator
 Random rand = new Random(reseed);
   // Delete any of these lines you don't need
   Rectangle selection = this.EnvironmentParameters.GetSelection(src.Bounds).GetBoundsInt();
   long CenterX = (long)(((selection.Right - selection.Left) / 2)+selection.Left);
   long CenterY = (long)(((selection.Bottom - selection.Top) / 2)+selection.Top);
   ColorBgra PrimaryColor = (ColorBgra)EnvironmentParameters.PrimaryColor;
   ColorBgra SecondaryColor = (ColorBgra)EnvironmentParameters.SecondaryColor;
   int BrushWidth = (int)EnvironmentParameters.BrushWidth;
   ColorBgra CurrentPixel;
   for(int x = rect.Left; x < rect.Right; x++)
       int lenght = rand.Next(selection.Bottom - selection.Top -1) + 1;
       for (int y = selection.Top; y < selection.Bottom; y++)
           if ((selectionRegion.IsVisible(x, y)) && (y<=lenght))
               if ((y <= lenght) && (y == 0 || (src[x,y - 1].A != 0)))
               CurrentPixel = src[x,y];
               // TODO: Add pixel processing code here
               // Access RGBA values this way, for example:
               CurrentPixel.R = 255;
               CurrentPixel.G = 255;
               CurrentPixel.B = 255;
               CurrentPixel.A = (byte)(255*(lenght-y)/lenght);
               dst[x,y] = CurrentPixel;
Any ideas?
Some answers here...
http://paintdotnet.12.forumer.com/viewtopic.php?t=4996
...the normal way for the renderer is 'for y...for x...'
meaning it works per lines and can't work per columns.
Your code Horizontaly:
 int reseed = 0;
       int lenght = rand.Next(Math.Abs(selection.Left - selection.Right - 1)) + 1;
           if ((selectionRegion.IsVisible(x, y)) && (x<=lenght))
               int xa = x -1;
               if (xa < rect.Left) xa=x;
               if ((x <= lenght) && (x == 0 || (src[x - 1,y].A != 0)))
                 CurrentPixel.A = (byte)(255*(lenght-x)/lenght);
 int reseed = 0;
               int xa = x -1;
(Madjik, yours works, but mine works better! JK, JK, Don't hit me...)
Is this what you're looking for?
(Note that I put a BLACK layer under it to properly illustrate...)
//Removed
ambigram signature by Kemaru
[i write plugins and stuff]
//Removed
try this:
//Removed
I noticed that my earlier version didn't "play nice" with layers that already had transparency on them, but now it should work no matter what is already on the layer you run the effect on. I also simplified some of the code.[/code]
try this:
//Removed
Well for one thing, like I've said a hundred times before, you don't need the following line of code.
if (selectionRegion.IsVisible(x, y))
Remove that will help performance.
Well the main problem that was causing the performance to be sooooo slow in Enormator's code was that he was using
instead of
[code]for (int y = rect.Top; y
essentially causing each and every call to Render() to process the [i]entire[/i] image instead of just the region that was passed by the rect argument.
instead of
AWESOME!
ill use the random one all the time
EDIT: bleh, i only thought that from the description. i would use it a lot if you made an option to change the size of the dots or the dots would be as big as your brush size
AWESOME!
Is there a way to easiliy draw a rectangle or do I have to use for x... for y...?
(That would be annoying to prog and probably slow in rendering)
This will draw a rectangle around the selection using your brushwidth...
   Rectangle selection = selectionRegion.GetBoundsInt();
   Graphics g = new RenderArgs(dst).Graphics;
   Pen p = new Pen(PrimaryColor.ToColor(),(float)BrushWidth);
   g.DrawRectangle(p, selection);
OK, In your earlier post you said that the bars were still repeating even with the version that I posted last, and that was because of a bug that I found and removed. This version is also just a teensy bit faster.
   Random rand = new Random(0);
   for(int x = rect.Left; x     {
       int length = rand.Next(selection.Bottom - selection.Top -1) + 1;
       for (int y = rect.Top; y         {
           CurrentPixel = ColorBgra.White;
           CurrentPixel.A = Utility.ClampToByte(255 * (length - y) / length);
Gives: untitleddj8.th.png
Now that's an awesome effect! I played around a little with CodeLab, and after a bit of figuring, I was able to change it to take a Length parameter from a single slider and use the Primary Color for the cascade effect.
It's probably sloppy, but it works, and it doesn't crash. :D
~ Becoming the Archetype
