m1rock Posted May 2, 2007 Share Posted May 2, 2007 Man im sorry for posting this as its been probably addressed but I just dont have the time to search though years of threads. Ok this is what I want to do. All I want to do is to select an object, move it and place it on top of another object. Like putting a hat on a persons head. I remember in MS paint this was quite simple as you just used a rectangle select, changed the background to transparent and moved it with you mouse...on here I cant figure it out, Ive moved backgrounds and nothing and created big checkerboard squares in my image to to point where im yelling obscenities at my computer screen. Any help before I go totally postal?? :evil: Thanks Quote Link to comment Share on other sites More sharing options...
Nesk Posted May 2, 2007 Share Posted May 2, 2007 You could use the Lasso Select tool to select the item that you want to cut out and put on another image, and the checkerboard means that the background is transparent. I think you should open your picture, and add a new layer, and add the item that you cut out to the new layer, then change the layer's properties to "Overlay". I think it should come up. If not, just check out this tutorial, it shows how to cut out images: http://paintdotnet.12.forumer.com/viewtopic.php?t=3434 Hope it helps Quote Link to comment Share on other sites More sharing options...
Myrddin Posted May 2, 2007 Share Posted May 2, 2007 Dude seriously change your thread title before it's locked and closed. EDIT, Nesk beat me: Checkerboard = transparent Quote How to Use Images in Your Posts, Signatures, and AvatarsHow to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
m1rock Posted May 2, 2007 Author Share Posted May 2, 2007 Thanks for the help guys. Ill try a few things. I dunno. maybe this isnt for me, I tend to get confused and frustrated easily. But I appreciate the help. you can lock and delete this if you want. Quote Link to comment Share on other sites More sharing options...
m1rock Posted May 2, 2007 Author Share Posted May 2, 2007 well Things kinda work but when I move my layer over my background its all faded and such. don't know why its like that. guess its kinda a stupid question by a stupid person situation. Quote Link to comment Share on other sites More sharing options...
barkbark00 Posted May 2, 2007 Share Posted May 2, 2007 m1rock, I think screen shots would help us understand what you are dealing with. Quote Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
