Derribong Posted April 15, 2007 Share Posted April 15, 2007 Try as I may,I cannot open .dll files.Have uninstalled Paint.Net and installed again(v3.05),all to no avail.My computer is running XP2 and IE7,which may not be compatible for Paint.Net.I have used BoltBait's Installing Effects in Paint,but still get the same message when I try to open a file= Caution, You are attempting to open a file of type 'Application Extension'(.dll) These files are used by the operating system and by various programs.Editing or modifying could damage yor system. Would very much like to use the plugins,so will be grateful if anyone has a solution. Quote Link to comment Share on other sites More sharing options...
MadJik Posted April 15, 2007 Share Posted April 15, 2007 Do not open the dll itself! The plugins are added to PdN and appear in the effect menu (generaly) and/or submenus. You have to open a picture file or image file or start with a new white page... Then click on the menu Effect and select the one you need/want... Quote My DeviantArt | My Pictorium | My Plugins | Donate via Paypal Link to comment Share on other sites More sharing options...
Derribong Posted April 15, 2007 Author Share Posted April 15, 2007 Have tried every way I know and the plugins don't show up in the effects,but thanks very much for trying to help me. I think I will give away trying to use plugins. Quote Link to comment Share on other sites More sharing options...
Bob Posted April 15, 2007 Share Posted April 15, 2007 Have you followed carefully the method described here: http://boltbait.googlepages.com/install ?? Did you installed Paint.NET in a different folder that the default one? Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to comment Share on other sites More sharing options...
Derribong Posted April 16, 2007 Author Share Posted April 16, 2007 Thank you Madjik and Bob for all your help. I did a clean uninstall then installed again,then followed the instuctions very closely and everything is working really well.Thanks again Quote Link to comment Share on other sites More sharing options...
usedHONDA Posted April 16, 2007 Share Posted April 16, 2007 ... And that's why I'm creating the Paint.NET Plugin Pack. Quote "The greatest thing about the Internet is that you can write anything you want and give it a false source." ~Ezra Pound twtr | dA | tmblr | yt | fb Link to comment Share on other sites More sharing options...
Bob Posted April 16, 2007 Share Posted April 16, 2007 Be sure to find automatically where PdN is installed. Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to comment Share on other sites More sharing options...
