jeydee Posted April 6, 2007 Share Posted April 6, 2007 Is there an easy way to draw double lines (parallel lines) like for drwing roads or walls? thanks. Quote Link to comment Share on other sites More sharing options...
verac the defiled Posted April 6, 2007 Share Posted April 6, 2007 Well i recommend the line/curve tool ( :LineCurveTool: ), holding shift while using it gives you a completely straight line. you might want to take note of the co ordinates that you draw your lines at to give you an idea where to start/finish the other. hope I Helped Quote Link to comment Share on other sites More sharing options...
jeydee Posted April 6, 2007 Author Share Posted April 6, 2007 Thanks for your reply. But that was not really my question. I want to be able to draw double lines together whether using the brush tool, the straight line tool or the free hand tool (think of it a very thick line using the brush tool but showing the ouline of the line only (without the solid fill inside) Quote Link to comment Share on other sites More sharing options...
barkbark00 Posted April 6, 2007 Share Posted April 6, 2007 For double lines I just: Open a new canvas. :AddNewLayer: Add a new layer. :LineCurveTool: Draw my single line. :DuplicateLayer: Then I Duplicate the layer. Now Select All (Ctrl+A:SelectAll:) and use the Move Selected Pixels Tool to move the copy of my first line to where I want it. Quote Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
usedHONDA Posted April 6, 2007 Share Posted April 6, 2007 BB00 seems to like the new buttons Brush types aren't available right now, but they should sometime next year or something. Quote "The greatest thing about the Internet is that you can write anything you want and give it a false source." ~Ezra Pound twtr | dA | tmblr | yt | fb Link to comment Share on other sites More sharing options...
barkbark00 Posted April 6, 2007 Share Posted April 6, 2007 Yeah, I have 'em memorized! Of course that's not as hard as it sounds... Quote Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
jeydee Posted April 6, 2007 Author Share Posted April 6, 2007 Thx barkbark00, works fine for straight lines, but not curves or circles. I just find out a way to do it using Outline (still experimenting with it). Open a new layer, select a very thick brush (25 pt or so), draw your lines, then select Ouline from the Effects menu. 1 Quote Link to comment Share on other sites More sharing options...
Bob Posted April 7, 2007 Share Posted April 7, 2007 :DuplicateLayer: Duplicate Layer, and Flip :Horiz: ?? Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to comment Share on other sites More sharing options...
MadJik Posted April 7, 2007 Share Posted April 7, 2007 Duplicate layer and... - Ctrl+Shif+Z to use the move or - Panelling plugin or - M, Ctrl+A, then cursor key Quote My DeviantArt | My Pictorium | My Plugins | Donate via Paypal Link to comment Share on other sites More sharing options...
jeydee Posted April 7, 2007 Author Share Posted April 7, 2007 Sorry MadJik, none of your suggestions works for this purpose, as already explaned above. Quote Link to comment Share on other sites More sharing options...
Tabletop Posted October 21, 2018 Share Posted October 21, 2018 On 4/6/2007 at 3:52 PM, jeydee said: Thx barkbark00, works fine for straight lines, but not curves or circles. I just find out a way to do it using Outline (still experimenting with it). Open a new layer, select a very thick brush (25 pt or so), draw your lines, then select Ouline from the Effects menu. Probably get in trouble posting to such an old thread, but jeydee's idea worked perfectly for me. Just drew my neighborhood street map for guests coming in town. Not a straight line in there and Google maps way too detailed. Used thick brush (black) and drew one street, new layer drew another, etc. Then went back to each layer and used outline from effects menu to turn into double line. Then eraser to remove extra lines between. Quote Link to comment Share on other sites More sharing options...
