sfchains Posted April 2, 2007 Share Posted April 2, 2007 Is there a way to maintain your tolerance levels for the Magic Wand and the Paint Bucket separate? Example - I use the Magic Wand and a low tolerance to grab a particular area and then when I want to fill that area with my chosen color, I select Paint Bucket and a high tolerance (I want to completely fill the selected area) When I am done with that area of the picture, I want to select a different area and when I select the Magic Wand the tolerance displayed is from my last Paint Bucket, meaning I have to go back up to the Tolerance and reduce it. And of course, when I am ready to fill this next area with color and I select Paint Bucket, the Tolerance shown is from the Magic wand........... Many thanks in advance for any suggestions Quote Link to comment Share on other sites More sharing options...
usedHONDA Posted April 2, 2007 Share Posted April 2, 2007 No way to do this. Quote "The greatest thing about the Internet is that you can write anything you want and give it a false source." ~Ezra Pound twtr | dA | tmblr | yt | fb Link to comment Share on other sites More sharing options...
BoltBait Posted April 2, 2007 Share Posted April 2, 2007 Try using the BACKSPACE key instead of the paint bucket. This is the same as using the paint bucket at 100% tollerance and it fills the selection with the primary color. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
