Issues with Transparent Background
Hi All,
I was able to do this a couple of weeks ago, but I am not sure why this is not the case now. I first would click on the magic wand and then click on the image (.png) background. Then I would press delete. Before it would become checkered and transparent, but now it turns black. Is there someone that would be able to help with this?
Thanks,
Alvin Tai
Mod note: unhelpful Photoshop answer hidden.
Hidden Content:
For some image magic wand may not work. You should create clipping path first with the name "path 1" 8fkVYO3.jpg?1
then select the path by pressing cntr+click path (image will be look like the above image.
after you can give feather (0.3) by pressing cntrl+alt+d
FS3eIwN.jpg?1
then press cntr+j and turn off the background off JEfOL1S.jpg?1
and save it .png formate
PiNGp80.jpg?1
You are done. I think thi is easier.
Thank you.
Edited by david.atwell
Not a Photoshop forum.
