ScrapbookWithPDN Posted October 15, 2015 Share Posted October 15, 2015 I looked to see where a place for suggestions went before posting this. I did a search using "Suggestions". This thread was all I could come up with so here is my suggestion....and I know these things take time. When one clicks on that gear icon in the top right corner of PDN and then when the box opens if one clicks on "TOOLS", I guess that's just for the "Tool Window" but somewhere within that whole pop up box, even before clicking on "Tools" can one have a place where they custom set the layout size of the canvas when PDN first opens up? Can there be a way to set it to, say, first open up using 12" x 12", as an example? or when PDN first opens, can there be yet another option added to the pop up box when one clicks on "New", so that, as an option, a box can be checked and it can be set to start the blank canvas to a designated size? Quote Link to comment Share on other sites More sharing options...
skullbonz Posted October 16, 2015 Share Posted October 16, 2015 That idea sounds like it could be more of an annoyance than a help. When you first open PDN or use the New option both pop up a box that gives you all the options you need for sizes and more. I am so used to inputting sizes that it's second nature to me now. Quote http://forums.getpaint.net/index.php?/topic/21233-skullbonz-art-gallery Link to comment Share on other sites More sharing options...
ScrapbookWithPDN Posted October 16, 2015 Author Share Posted October 16, 2015 637 It wouldn't be annoying for projects using the identical size each time PDN is open. I'm thinking having a way to pre-select or customize various functions saves time for others, too, since that feature has been incorporated under Settings>Tools. Quote Link to comment Share on other sites More sharing options...
