Flat Stanley Posted March 8, 2007 Share Posted March 8, 2007 Working letter size, with 4 layers at 300dpi is quite slow for me. I have a recent dual core processor with one GB of ram. Are there any recommended ways of speeding things up? For instance, can you increase the amount of hard drive space available to paint.net? Or are there some options which need turning on or off?? Any suggestions would be appreciated. Kind Regards // Stanley Quote Link to comment Share on other sites More sharing options...
Bob Posted March 8, 2007 Share Posted March 8, 2007 Reduce dpi. (3000 x 8000 px size, am I right?) Buy branded hardware (Ram is your case). not no name stuff. I mean with good bus and such. Buy a Quad-Core. (Duo Core Quad or whatever's its name, it's the last Intel chip) or wait for the eight one. It helps A LOT: http://blogs.msdn.com/rickbrew/archive/ ... cores.aspx I think hard drive does not really affect here, apart for load/save and maybe history (take care to format it in NTFS) That's not really PdN specific hints, it just basic h/w updating. Also, it depends on what tasks you achieve with your pictures, if it's adding lot of effects, or painting or idk else. As always, I might be totally wrong. Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to comment Share on other sites More sharing options...
usedHONDA Posted March 8, 2007 Share Posted March 8, 2007 Ctrl+Alt+Delete>Process tab>CPU usage>End the process taking up the greatest amount of CPU (Internet Explorer normality takes up lots of CPU for me). EDIT: Oh, and this would help. Quote "The greatest thing about the Internet is that you can write anything you want and give it a false source." ~Ezra Pound twtr | dA | tmblr | yt | fb Link to comment Share on other sites More sharing options...
Myrddin Posted March 8, 2007 Share Posted March 8, 2007 This may not have the intended result but would this work?: http://img59.imageshack.us/img59/4100/untitledrz6.jpg Read about it somewhere, could have even been on here but I've slept since then, if I'm wrong sorry. Quote How to Use Images in Your Posts, Signatures, and AvatarsHow to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
Rick Brewster Posted March 8, 2007 Share Posted March 8, 2007 Switching PaintDotNet.exe to high priority is probably a bad idea. Really, if you want great performance, here's the things you do or want: 1) Have lots of memory. 256MB is the minimum but you really want 1 or 2 GB if you're working with large images. Less memory means more hard drive use which is extremely slow. 2) Have a dual-core processor. Paint.NET is heavily optimized for multicore systems. 3) Use 64-bit Windows. More RAM and better performance. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Myrddin Posted March 8, 2007 Share Posted March 8, 2007 Could I ask then Rick, why is setting PDN.exe to high priority a bad idea? Quote How to Use Images in Your Posts, Signatures, and AvatarsHow to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
Illnab1024 Posted March 8, 2007 Share Posted March 8, 2007 If it overtakes a system process on a critical function, there could be some malicious ramifications, I guess... Quote ~~ Link to comment Share on other sites More sharing options...
usedHONDA Posted March 8, 2007 Share Posted March 8, 2007 ramifications Main Entry: ram·i·fi·ca·tion Pronunciation: "ra-m&-f&-'kA-sh&n Function: noun 1 a : BRANCH, OFFSHOOT b : a branched structure 2 a : the act or process of branching b : arrangement of branches (as on a plant) 3 : CONSEQUENCE, OUTGROWTH Anyway, yeah, don't change the priority. I've done it. If you put it high, the computer crashes for 10 minutes and if you make it lower, it just goes slow. Quote "The greatest thing about the Internet is that you can write anything you want and give it a false source." ~Ezra Pound twtr | dA | tmblr | yt | fb Link to comment Share on other sites More sharing options...
Flat Stanley Posted March 8, 2007 Author Share Posted March 8, 2007 thanks for all the advice guys. From the nature of your replies, it seems that this kind of slow down is not a common problem. I will take the offending file home and try it on my desktop. Its an athlon 64 with 1gb of OCZ ram. I'll let you know what happens..... Thanks again //stanley Quote Link to comment Share on other sites More sharing options...
usedHONDA Posted March 8, 2007 Share Posted March 8, 2007 Try restarting the computer (or hibernating). That will make it feel good, which will thus make you feel good. Quote "The greatest thing about the Internet is that you can write anything you want and give it a false source." ~Ezra Pound twtr | dA | tmblr | yt | fb Link to comment Share on other sites More sharing options...
The_Lionhearted Posted March 9, 2007 Share Posted March 9, 2007 Try restarting the computer (or hibernating). That will defragment the system and make it feel good, which will thus make you feel good. ...? Restarting a computer doesn't defragment it... :? Quote My Gallery Link to comment Share on other sites More sharing options...
usedHONDA Posted March 9, 2007 Share Posted March 9, 2007 Well there was some other word like defragment that's supposed to describe it. Quote "The greatest thing about the Internet is that you can write anything you want and give it a false source." ~Ezra Pound twtr | dA | tmblr | yt | fb Link to comment Share on other sites More sharing options...
The_Lionhearted Posted March 9, 2007 Share Posted March 9, 2007 Restart? Refresh? Renew? Sounds like a deodorant commercial. Quote My Gallery Link to comment Share on other sites More sharing options...
Rick Brewster Posted March 9, 2007 Share Posted March 9, 2007 Could I ask then Rick, why is setting PDN.exe to high priority a bad idea? I'm guessing it's a single core/processor system (just playing the statistics here -- most people don't have brand new computers). If Paint.NET starts running away with high CPU usage, it will make the rest of the system unusable because you said you want Paint.NET to have priority. In my experience and opinion, there's really only two times to muck with the priorities: 1) You have something that uses a lot of CPU and you want it to run in the background, effectively only using spare CPU cycles that nobody else is using. An example would be if you are doing a large compression job and you want to keep going about doing some other stuff. Having a dual- or quad-core system is actually making this less of an issue. If I have some large compression job going on the side (e.g. I'm making a ZIP file of the Paint.NET CVS server so I can do a backup), and if I had a quad-core system ... then I've still got 3 cores leftover that can do stuff at full speed. 2) You have a real-time application (e.g., MP3 player) that seems to be misbehaving by way of skipping audio or something, and you notice weird CPU usage patterns surround it. Sometimes setting these to a higher priority can alleviate that. When the real-time app needs CPU time, then by golly it is going to get it. But by the nature of the application it isn't going to be using a constant amount of CPU time -- maybe 100ms every 2 seconds or something. The foreground application automatically receives a priority boost anyway. I can almost guarantee that the computer is going to do a better job of managing thread scheduling than you can. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Myrddin Posted March 9, 2007 Share Posted March 9, 2007 Thanks for that, luckily though it was only PDN that I set to high so hope nothing too serious will come of it. Quote How to Use Images in Your Posts, Signatures, and AvatarsHow to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
