Saitentanz Posted September 9, 2015 Share Posted September 9, 2015 (edited) The foto below is mounted in PDN by using a few layers. I want to light up the rings on the left by using the elipse tool and their combination: An inner circle for the inside edge (holding the ctrl-key) and another one for the outside edge using the subtraction mode. After lifting the finger from left mouse key the masking disappears. So there is no way masking the rings properly. What can I do? Edited September 9, 2015 by Saitentanz Quote Link to comment Share on other sites More sharing options...
Pixey Posted September 9, 2015 Share Posted September 9, 2015 Hi Saitentanz ............ perhaps this thread will be of help to you. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Saitentanz Posted September 10, 2015 Author Share Posted September 10, 2015 Hi Pixey, unfortunately no. It seems my English is not skilled enough. I don´t understand the instructions given in that thread. Normally it should work in the reduction mode. Is there any online tutorial on this problem? Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted September 10, 2015 Share Posted September 10, 2015 Try selecting the entire ring first. Once you have that use the ALT key modifier (Subtract mode) to remove the center of the first selection. REF: http://www.getpaint.net/doc/latest/ShapeSelectionTools.html under heading Subtract. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Saitentanz Posted September 10, 2015 Author Share Posted September 10, 2015 Ok, using ALT I can mask the rings. But if I want to lighten in up, then no reaction is being shown. What am I still doing wrong? Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted September 11, 2015 Share Posted September 11, 2015 Once you have the ring selected, apply Adjustments > Brightness and Contrast to your liking. Then select the next ring and apply the same modification. The settings will persist in the B&C dialog - so all you need to do is accept the changes by clicking Ok. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Saitentanz Posted September 11, 2015 Author Share Posted September 11, 2015 (edited) Ooops, I´ve been in the wrong layer Thx. Finally it´s worked Edited September 11, 2015 by Saitentanz Quote Link to comment Share on other sites More sharing options...
