Eli 1,129 Posted August 16, 2015 Report Share Posted August 16, 2015 I have these ones also : Quote Link to post Share on other sites
TechnoRobbo 1,166 Posted August 16, 2015 Author Report Share Posted August 16, 2015 When zooming in on a large image / canvas, is there any keyboard shortcuts in order to move around the image ? When I zoom in close on an image there doesn't seem to be a way to pan around it. Right Click and drag image around - If you forget theres some instructions at the bottom https://www.dropbox.com/s/re58v5wr3vtqvhe/DnBCapture.PNG?raw=1 1 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Eli 1,129 Posted August 16, 2015 Report Share Posted August 16, 2015 TR, do you think it would be possible to apply the effect on a transparent layer? Quote Link to post Share on other sites
mottoman 296 Posted August 16, 2015 Report Share Posted August 16, 2015 Thanks TR, never noticed that Quote Link to post Share on other sites
TechnoRobbo 1,166 Posted August 16, 2015 Author Report Share Posted August 16, 2015 TR, do you think it would be possible to apply the effect on a transparent layer? It's an adjustment brush - all effects modify an image. The Dodge and Burn use a color matrix and all the others are Built-in PDN adjustments applied in brush form. As Billie Preston once said, "nothing from nothing leaves nothing, you gotta have something" 1 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Eli 1,129 Posted August 16, 2015 Report Share Posted August 16, 2015 (edited) You are right. I guess we have something to start another project. An idea. Edited August 16, 2015 by Eli Quote Link to post Share on other sites
TechnoRobbo 1,166 Posted August 16, 2015 Author Report Share Posted August 16, 2015 Version 1.3.14+ Ready for Download New Brush Designs by Eli, Enhanced Zoom (Zoom Out!!) 2 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
TechnoRobbo 1,166 Posted August 17, 2015 Author Report Share Posted August 17, 2015 Post removed Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
TechnoRobbo 1,166 Posted August 17, 2015 Author Report Share Posted August 17, 2015 Version 1.3.15+ Ready for Download ColorBlend and Luminosity Modes suggested by Pratyush These Modes are inspired by a famous Photography Shop program. Color Blend Replaces Hue and Saturation without affecting Lightness Luminosity Replaces Lightness without affecting Hue and Saturation Post Edit - please re-download Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
TechnoRobbo 1,166 Posted August 18, 2015 Author Report Share Posted August 18, 2015 Version 1.3.17+ Fixes Luminosity and Add Mouse Wheel Control Ready for Download Luminosity will now behave exactly like another Photography Shop Software's Luminosity 2 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Maximilian 1,927 Posted August 18, 2015 Report Share Posted August 18, 2015 Thanks for the ongoing updates, TR! You are a super guy! Quote Link to post Share on other sites
Cc4FuzzyHuggles 320 Posted September 3, 2015 Report Share Posted September 3, 2015 Hello. I finally wanted to try this plugin out. Unfortunately, I've run into a few problems.I'm not sure how the plugin is supposed to normally work, so maybe some of these things are fine.- The UI control area seems to be cut off on my screen. I think I can see the edge of it a little in the upper right. http://s5.postimg.org/6l1qkh0pj/TRDodge_Burn_Whereis_UI.jpg - When I clicked to at least see what would paint, nothing happened. Not sure if I need to select an effect first, like burn or dodge, but since I can't see the control area I can't do that.- When I "Restore Down" the window isn't an adjustable scalable window. Some of my Display details :My computer monitor's native resolution is 1920 x 1080.I have my computer's "Display" setting to Medium - 125%. http://s5.postimg.org/7foa6i8k7/Windows_7_Display_125.png My PC Specs : Hidden Content: Application paint.net 4.0.6 (Final 4.6.5693.28)Build Date Monday, August 03, 2015Hardware accelerated rendering (GPU) TrueAnimations FalseDPI 120.00 (1.25x scale)Language en-USOS Windows 7 Service Pack 1 (6.1.7601.65536).NET Runtime 4.0.30319.34209Physical Memory 1,790 MBCPU AMD Athlon II X2 215 ProcessorArchitecture x86 (32-bit)Process Mode 32-bitSpeed ~2700 MHzCores / Threads 2Features DEP, SSE, SSE2, SSE3Video Card AMD 760GDedicated Video RAM 253 MBDedicated System RAM 0 MBShared System RAM 639 MBVendor ID 0x1002Device ID 0x9616Subsystem ID 0x360017AARevision 0LUID 0x00008FF5Flags NoneOutputs 1 Quote *~ Cc4FuzzyHuggles Gallery ~* Link to post Share on other sites
TechnoRobbo 1,166 Posted September 3, 2015 Author Report Share Posted September 3, 2015 When I clicked to at least see what would paint, nothing happened. Not sure if I need to select an effect first, like burn or dodge, but since I can't see the control area I can't do that. Increase the exposure then Click and drag - Every subsequent pass will increase the effect My computer monitor's native resolution is 1920 x 1080.I have my computer's "Display" setting to Medium - 125% I'm going to have to borrow my sons screen for testing. Look for an update soon Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
TechnoRobbo 1,166 Posted September 3, 2015 Author Report Share Posted September 3, 2015 I tested at 1920 x 1080 at 125% but I could not reproduce that effect. I made an educated change (a guess) tell me if it worked. https://www.dropbox.com/s/kviswtmk7ftcglo/cc4f.png?raw=1 Version 1.3.18+ tested to 192 DPI at 1920 x 1080 Ready for download. 1 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Cc4FuzzyHuggles 320 Posted September 3, 2015 Report Share Posted September 3, 2015 I did a quick test. I can now see the controls. Your exposure advise worked. Thanks. Quote *~ Cc4FuzzyHuggles Gallery ~* Link to post Share on other sites
TechnoRobbo 1,166 Posted September 4, 2015 Author Report Share Posted September 4, 2015 Your Welcome Cc Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Ishi 194 Posted September 5, 2015 Report Share Posted September 5, 2015 This is an amazing plugin. Really a must have. Thanks TR. Any chance that you and Rick could perhaps incorporate this into the main PDN user interface via the floating "Tools" menu? That would be great... Quote Link to post Share on other sites
TechnoRobbo 1,166 Posted September 5, 2015 Author Report Share Posted September 5, 2015 Ask Rick. If he wants he can have any of my code. Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Ishi 194 Posted September 5, 2015 Report Share Posted September 5, 2015 Perhaps send him a PM about this? I really think this deserves to become native on a future version of PDN. Its some of the main bits that should be on the Tools menu like other image manipulation software. Quote Link to post Share on other sites
racerx 273 Posted September 10, 2015 Report Share Posted September 10, 2015 Using the De-Saturation brush is a great way to reduce Red-Eye caused by camera flash. It also works well for pets eyes.... 2 Quote Link to post Share on other sites
Eli 1,129 Posted September 11, 2015 Report Share Posted September 11, 2015 Thanks racerx, Great thinking! It is a great use of the effect, Quote Link to post Share on other sites
Seerose 4,273 Posted September 28, 2015 Report Share Posted September 28, 2015 @TechnoRobbo! Thank you so much. I've combined so. I don't know whether that's so right? *Photo: From my garden 3 Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to post Share on other sites
TechnoRobbo 1,166 Posted September 28, 2015 Author Report Share Posted September 28, 2015 Very pretty, Water Lilly 1 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Ishi 194 Posted December 23, 2015 Report Share Posted December 23, 2015 (edited) Hello TR, My issue with this plugin is that it seems to render slow on my computer. For instance, when I use the blur function, there are a few second delays before it does the blurring on the selected area. I seem to have experienced slow rendering issues with some of your plugins that I tried, one of which is the Bokeh plugin I have told you about last year. It has to do with some of your rendering algorithm perhaps? I use a low spec netbook machine. Its specs are : Windows 8.1 2GB RAM Processor Intel® Atom CPU N2600 @ 1.60GHz, 1600 Mhz, 2 Core(s), 4 Logical Processor(s) If there's anything you can do to improve the rendering speed of your plugins for machines with specs comparable to mine, that would be greatly appreciated as that would mean better usability of your plugins for low end computers as well. This happens on low resolution images as well. Thank you. Edited December 23, 2015 by Ishi Quote Link to post Share on other sites
Eli 1,129 Posted December 23, 2015 Report Share Posted December 23, 2015 Hello Ishi, Do you have many effects installed? I do and I experience the same problems as you do. I noticed that effects work better/faster when I remove the effects I do not need and place them to a temporary folder. Quote Link to post Share on other sites
