Rockster Posted August 3, 2015 Share Posted August 3, 2015 Hi paint.net users I have a suggestion for paint.net because it has come me to mind that there isn't a color replace function. It works like follow: If you make a ctrl command like ctrl h with the color in your pallet like red and that you can select a secondary color like blue that it changes all the red to blue. (This idea came to me when the magic wand wasn't doing his job as i wanted and sometimes two colors don't fit together and that you have to change all the pixels with the not good color) Greetz and maybe some things there could change in this idea Quote Link to comment Share on other sites More sharing options...
BoltBait Posted August 3, 2015 Share Posted August 3, 2015 Paint.NET does have a way to replace color: Recolor Tool. Or, you could try one of the plugins in my plugin pack, Hue / Saturation+ http://forums.getpaint.net/index.php?/topic/28613- Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
midora Posted August 3, 2015 Share Posted August 3, 2015 Hi Rockster, the 'Paint Bucket' tool has a flood mode which you can set to 'global'. If you are clicking a color in the image then all simular pixels will be replaced. Quote Link to comment Share on other sites More sharing options...
Cc4FuzzyHuggles Posted August 3, 2015 Share Posted August 3, 2015 This plugin also helps to re-color things: http://forums.getpaint.net/index.php?/topic/24584-recolour-choice/ Quote *~ Cc4FuzzyHuggles Gallery ~* Link to comment Share on other sites More sharing options...
