BoltBait's Plugin Pack for PdN v4.0.6+ Updated Aug 16, 2017
BoltBait
On 9/11/2018 at 5:42 PM, BoltBait said:
If you can't... that's cool.  Just enjoy the plugins.
BTW, I'm updating my plugin pack at the moment.  Come back next week!
I first want to say thank you very much! Secondly how would I be notified of any future updates you do?
I don't really update my pack very often, but I'll be publishing an update to my plugin pack next weekend.
BTW, if you ever want to know if my plugins have been updated, just run the installer.exe again and it will prompt you to download the updated pack.
  • BoltBait unpinned this topic
41 minutes ago, welshblue said:
What am I doing wrong ?
Run the installer and click the "All" link button in the upper right corner of the install screen.
Then, click the Install button.
When prompted, click Overwrite.
6 minutes ago, welshblue said:
I'm currently using Store 4.1.1
That could be it!
If the installer finds the effects folder under C:\program files\Paint.NET\Effects, it will install the plugins there.
If you want to have the installer put your plugins in the proper folder for the store version, you'll need to delete that folder (or rename it temporarily).
Then, the installer won't find it and will then prompt you for where to install the plugins.
  • 4 years later...
30 minutes ago, Dain0 said:
I was wondering if this would work on the newest update of the application?
No, this is an out-of-date version.
You need to use the most recent version; found here:
https://forums.getpaint.net/BoltBaitPluginPack
My Gallery  |  My Plugin Pack
Layman's Guide to CodeLab
