Popular Post midora Posted July 8, 2015 Popular Post Share Posted July 8, 2015 (edited) 'ZIP Archive' FileType Plugin (.ZIP) Download Find the latest version of the plugin here: ImZIP.FileType.v1.4.zip[2021-11-04] Summary Loads/saves the content of a Paint.NET document (layers and metadata) from/to a compressed ZIP Archive. Each layer will be a separate file in the archive (or if the tiling feature is used a set of files where each file contains one tile). Several formats for the layer files are supported: PNG, BMP, GIF, and JPEG. Additionally a thumbnail and a composite image can be stored in the archive. Tiling of the image is possible. Save may chop up the layers into tiles and load will glue the tiles together to the original image. This file format may be used to export the layers to an other application in a standard format. to zip the image if an upload location does not allow .pdn format. as a replacement for the external Paint.NET tool LayerSaver Keywords FileType, ZIP, Archive, Save layers, Load Layers, Split layers, Tiles Author / Copyright Martin Osieka 2015-2021, Martin Osieka, Switzerland You may use this plugin together with Paint.NET w/o any restriction. Installation Follow the instructions carefully Copy the folder 'ImZIP.FileType' together with its content into FileTypes folder of paint.net Remove other plugins supporting the same file type (.zip) from FileTypes folder (to avoid possible conflicts) I.e. 'TileImageFileType.dll' plugin. To verify the installation you should restart Paint.NET and check that the filetype popup of the 'Open...' file dialog contains an entry starting with ZIP. Compatibility Paint.NET >= 4.3.2 Supported languages The language used in the plugin depends on the language setting of Paint.NET and the support of this language by the plugin. The fallback is the first supported language of the plugin. Languages are defined in the .dlc files. This plugin supports the following languages in the moment: English Deutsch 'Save dialog' options Layer subset Select 'All layers', 'Visible layers', or 'Hidden layers'. If the resulting layer set is empty you will get an error message box. Just continue and select an other layer set. Save formats of images The following formats are available in the moment PNG 32-bit ARGB BMP 32-bit ARGB GIF 8-bit RGB opaque (loosy) JPEG opaque (loosy) Only PNG ARGB and BMP ARGB allow you to load the zip back in the original quality. Because GIF and JPEG do not support an alpha channel, the layers will be rendered against a white background before saving. You can see this in the preview window. Thumbnail (preview image) If checked then a file 'Thumbnail.png' will be added as the first entry to the zip. This allows shell extensions of Windows File Explorer to show a preview of the zip. A thumbnail is not required to restore the Paint.NET document. Composite (flattened image) If checked then a file 'Composite.EXT' will be added to the zip. The extension depends on the selected image format. The composite has the same size as the layers. A composite is not required to restore the Paint.NET document. Tiling of layers The layer content can be splited in square or rectangular tiles. Typically this is used on flattened images but it works on a layered image too. Decreasing the size of the tiles will slow down the processing and increase the number of files in the archive. 'Load dialog' options None ZIP file content A ZIP file describing a Paint.NET v3 document may contain the following files: 'PaintDotNet.txt' A txt file in UTF-8 format (starting with an UTF-8 BOM: 0xEF 0xBB 0xBF) In the moment the file just contains the signature text "PDN3" which means that the zip file describes a version 3 Paint.NET document completely. 'Thumbnail.png' A 32-bit ARGB png image containing the composite image of the document scaled down to a maximum size of 256 x 256 pixels (respecting the aspect ratio). Thumbnail.png should be the first file in the zip archive to support shell viewers which show the first image in the zip file in Windows FileExplorer. 'Composite.EXT' A composite (flattened) image in the requested image format. 'L{id},R{row},C{column},{name},{visibility},{mode},{opacity}.EXT' All layers of the document are stored in the selected image format. The file name of a layer starts with the character 'L' and contains the following elements {id}: The decimal index of the layer in the range [1..Z]. 1 is the bottom layer. The index may be preceded by '0' characters. {row}: The decimal index of the row in the range [1..Y]. {column}: The decimal index of the column in the range [1..X]. {name}: The name of the layer. Unicode letters and digits are used directly but all other characters will be replaced with their 32-bit hexcode preceded with the character %. I.e. a comma in the name will be replaced with %002C. {visibility}: may be 'visible' or 'hidden' {mode}: Is the blend mode of the layer in lowercase letters, I.e. 'normal' {opacity}: The opacity value of the layer in the range [0..255]. 255 is opaque. The loader checks all file names in the archive for the pattern L{z},R{y},C{x} sorts them and glues all tiles of a layer together. The image with id 'L1' defines width, height, and dpi value of the document. Known issues Paint.NET does not inform the filetype plugin that the save operation has been aborted because the user changed a parameter of the dialog. This slows down the time needed to compute the size of the file. So avoid to change the parameters too fast. History 1.4 [2021-11-04] - Replaced ionic zip class with ZipArchive class 1.3 [2021-11-02] - Modified to support paint.net 4.3 and .NETCore 5 1.2 [2021-08-17] - Refactored. Added 'Layers subset' option 1.0 [2015-07-08] - First public release Edited January 16, 2022 by midora 2 8 Quote Link to comment Share on other sites More sharing options...
midora Posted July 8, 2015 Author Share Posted July 8, 2015 Thanks to Pratyush to remind me that there was no release yet. See Alternative to LayerSaver. Quote Link to comment Share on other sites More sharing options...
Maximilian Posted July 10, 2015 Share Posted July 10, 2015 I've been testing it and it works very well. Thanks for the efforts, Martin! Quote Link to comment Share on other sites More sharing options...
Nichromo221 Posted August 10, 2015 Share Posted August 10, 2015 I'm a complete noob to plugins, but I followed the directions, and put the plugins where plugins usually go (In the effects folder right?) But it still doesn't work, I am using one of the versions its compatible with, version 4.0.5 but it still doesn't work. I mean, how do I get the option to show? Like save it as a regular .PNG file?Basically what I'm asking is how do I use the plugin when I have it installed. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 10, 2015 Share Posted August 10, 2015 Not quite. Filetype plugins go in the \Filetypes\ folder, not \Effects\. From the first post... Follow the instructions carefully Copy the two files 'ImZIP.FileType.dll/.dlc' to the Paint.NET\FileTypes\ folder Remove other plugins supporting the same file type (.zip) from Paint.NET\FileTypes\ folder (to avoid possible conflicts) I.e. 'TileImageFileType.dll' plugin. To verify the installation you should restart Paint.NET and check that the filetype popup of the 'Open...' file dialog contains an entry starting with ZIP. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Cc4FuzzyHuggles Posted October 11, 2015 Share Posted October 11, 2015 (edited) Basically what I'm asking is how do I use the plugin when I have it installed. When installed correctly, Go up to the Menu Bar in paint.net > File > Save As > click the Save As Type drop down list > look for "ZIP - Compressed Archive of Layers (*.zip)", and then click "Save". The plugin's user interface should pop up. Edited October 11, 2015 by Cc4FuzzyHuggles Quote *~ Cc4FuzzyHuggles Gallery ~* Link to comment Share on other sites More sharing options...
Hypure Posted November 8, 2015 Share Posted November 8, 2015 (edited) Perfect. Just what I was looking for. You are awesome.....Let it be known from this day forward. Edited November 9, 2015 by Hypure Quote Link to comment Share on other sites More sharing options...
Gio Posted April 18, 2016 Share Posted April 18, 2016 'ZIP Archive' FileType Plugin (.ZIP) I tried and it's very useful. My compliments for your work! Quote Link to comment Share on other sites More sharing options...
Hanako Seishin Posted March 10, 2019 Share Posted March 10, 2019 Doesn't work for layers with non-latin characters in their names. Quote Link to comment Share on other sites More sharing options...
AhmedElyamani Posted May 18, 2019 Share Posted May 18, 2019 This plugin is very useful! Thank you, I appreciate your effort. Quote Link to comment Share on other sites More sharing options...
Kanser Posted June 25, 2019 Share Posted June 25, 2019 Is it possible to prevent the layer names from being changed in the archive? For example, in paint.net my first layer is "01". When I save it into an archive, I would like to keep it as "01", instead of "L3,R1,C1,01,visible,normal,255". 1 Quote Link to comment Share on other sites More sharing options...
AP2020 Posted January 17, 2021 Share Posted January 17, 2021 Great Plugin! I would just like to be able to convert an entire folder of pdn files into layers, or alternatively those currently open. Quote Link to comment Share on other sites More sharing options...
Djisves Posted January 18, 2021 Share Posted January 18, 2021 @AP2020, you do not need a plugin for that. On the Menu Bar, click on Layers > Import from File... and select as many files as you need. (I've only ever tried it with files within the same folder). More here. Quote Link to comment Share on other sites More sharing options...
AP2020 Posted January 20, 2021 Share Posted January 20, 2021 Sorry @Djisves, your idea is good but it has 2 problems: I have a many images and the computer crashed, processing one file at a time I suppose wouldn't have happened; also my files have different sizes, so all the extracted layers would have been the size of the biggest image. Maybe I was explaining myself wrong. My intention was not only to convert to layers, but also to export them to png Quote Link to comment Share on other sites More sharing options...
Reptillian Posted January 20, 2021 Share Posted January 20, 2021 (edited) 21 minutes ago, AP2020 said: Sorry @Djisves, your idea is good but it has 2 problems: I have a many images and the computer crashed, processing one file at a time I suppose wouldn't have happened; also my files have different sizes, so all the extracted layers would have been the size of the biggest image. Maybe I was explaining myself wrong. My intention was not only to convert to layers, but also to export them to png Then you would need to use a batch processing software. Either ImageMagick or G'MIC would work. I could help you with G'MIC with a PM though. Also, do report your bug to @Rick Brewster. I think the import layers to zip method to extract should work. If not, you always have the above method. Edited January 20, 2021 by Reptillian Quote G'MIC Filter Developer Link to comment Share on other sites More sharing options...
aworkerb Posted February 26, 2021 Share Posted February 26, 2021 I just installed the files into the FileTypes folder but ZIP doesn't appear in the Open or Save As options. I'm on 4.2.15 -- anyone using it successfully with the latest version? Quote Link to comment Share on other sites More sharing options...
midora Posted February 26, 2021 Author Share Posted February 26, 2021 PDN 4.2.15 Quote Link to comment Share on other sites More sharing options...
aworkerb Posted February 26, 2021 Share Posted February 26, 2021 Ugh. Even removing everything else from FileTypes didn't help. Well, thanks for the reply. Quote Link to comment Share on other sites More sharing options...
midora Posted February 26, 2021 Author Share Posted February 26, 2021 @aworkerbDid you check if Settings->Plugin Errors tells you something about an exception? Maybe it is just an installation issue. Quote Link to comment Share on other sites More sharing options...
aworkerb Posted February 26, 2021 Share Posted February 26, 2021 1 hour ago, midora said: @aworkerbDid you check if Settings->Plugin Errors tells you something about an exception? Maybe it is just an installation issue. Good idea. Unfortunately, "there were no errors encountered while loading plugins". Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted February 27, 2021 Share Posted February 27, 2021 On 2/26/2021 at 4:20 PM, aworkerb said: I just installed the files into the FileTypes folder but ZIP doesn't appear in the Open or Save As options. I'm on 4.2.15 -- anyone using it successfully with the latest version? Did you do these two steps.....? Quote Copy the two files 'ImZIP.FileType.dll/.dlc' to the Paint.NET\FileTypes\ folder Remove other plugins supporting the same file type (.zip) from Paint.NET\FileTypes\ folder (to avoid possible conflicts) I.e. 'TileImageFileType.dll' plugin. If you did, post a screenshot of your FileTypes folder showing us what's in there. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
midora Posted March 2, 2021 Author Share Posted March 2, 2021 Is there the possibility that you mixed up the two paint.net variants Standard and Shop? Then there are different FileType folders. I would expect that paint.net throws an exception if the dll is in the right folder but access is denied. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted March 3, 2021 Share Posted March 3, 2021 Quote post a screenshot of your FileTypes folder showing us what's in there. I recommended this ^ so we can also check the path is correct. That's what @midora is talking about. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
aworkerb Posted March 3, 2021 Share Posted March 3, 2021 10 hours ago, Ego Eram Reputo said: I recommended this ^ so we can also check the path is correct. That's what @midora is talking about. Well, I guess a picture's worth at least a couple of words. Here's where I installed the files. But see my forehead-smacking realization bolded farther down... 19 hours ago, midora said: Is there the possibility that you mixed up the two paint.net variants Standard and Shop? Then there are different FileType folders. I would expect that paint.net throws an exception if the dll is in the right folder but access is denied. I'm not sure what the "Shop" version is, unless you mean the Microsoft Store? I've only ever had the standalone version. HOWEVER, your post made me poke around and finally notice that there were NO OTHER FILES in the parent folder of my FileTypes folder, only a handful of other folders (Effects, Shapes, Staging). That's because everything else is where the program actually lives, Program Files (x86), not plain old Program Files. I moved the filetype libraries to the correct folder, and now I can save out ZIP files. Too bad the reason I went down the path in the first place has come and gone. But I'll be ready for next time. Thanks for the help and motivating me to look more carefully. Quote Link to comment Share on other sites More sharing options...
midora Posted August 18, 2021 Author Share Posted August 18, 2021 ImZIp has been updated to version 1.2. This version added the feature to save all layers, visible only, hidden only, ImZIP.FileType v1.2.zip Sorry that I'm not able to put it in the first thread but I lost the account email years ago. 2 1 Quote Link to comment Share on other sites More sharing options...
