Sign in to follow this
MJW
Texture Shader
The Planetoid controls are very well done. I'll give it some serious consideration.
Not that it really matters much, but does Planeload use a separate DLL for the controls or are they all in one DLL? Does it use ILMerge in the build process? Also, are the controls added to the forms with programmer-written code, or are they done using the VS Designer?
Share this post
Link to post
The sliders, color selector control, and roll control are the custom ones. These start as a separate VS project, built and then added to the toolbox. Using them from the toolbox is just like any other tool. Yes I used VS form designer, no to ILmerge.
Share this post
Link to post
It would be a great late Christmas present if your 2 brains had a solution, but not the end of the world if not.
Thanks for looking into it
Share this post
Link to post
I've released version 2.2.0, which has a new mapping mode called Reflection Map (Equirectangular). It should be useful for producing such things as chrome text. (Reflection mapping is also referred to as "environment mapping.") It's a feature I've intended to add for a long time, and finally gotten around to. Though it doesn't replace the other reflection mapping modes, it's probably the most generally useful.
Equirectangular images are 360° spherical images that represent the image in equally-spaced latitude-longitude format. There are many available on the Internet, including those on the Equirectangular Flickr group.
Some things to note (which I'll add to as I think of them):
- Though image scaling is supported, values other than the default value of 1 may not produce useful results.
- Likewise, though the normal Image mode is Clipboard, the other modes are supported, and may sometimes be useful when the image scale factor is less than 1.
- Although equirectangular projections are normally twice as wide as they are tall, all aspect ratios are treated as full sphere maps.
-  The offset controls are used to rotate the image sphere about the X and Y axes, while the Rotation control rotates it about the Z axis. The Z rotation is applied last, so it will rotate the sphere that has been rotated about Y and tilted about X.
- Standard reflection mapping considers the sphere to be at infinity, so that for a directional eye vector, only the surface normal matters, not the position of the point. The Reflection Map (Equirectangular) mapping mode allows the sphere radius to be changed, so the reflection varies, even for a flat surface. A Mapping Displacement of 0 specifies an infinite sphere. Increasing the displacement decreases the sphere size. If the sphere is so small that the height-map points are outside the sphere, they will be transparent. The value at which this occurs depends on the canvas size (for obvious reasons).
- Standard equirectangular projections have the following characteristics: They're twice as wide as they are high, since the width represents 360° and the height represents 180°; the top row of pixels and the bottom row of pixels are constant, since the top row represents the sphere's topmost point, and the bottom row represents the sphere's bottommost point; the left edge (nearly) matches the right edge, since the image wraps around.
-  For many situations, images that are not actual equirectangular projections will produce useful results. However, using, for instance, an image that doesn't match at the left and right edge may limit the positions that the sphere can be rotated to without the seam becoming visible.
- Often, it's more effective to use mostly ambient lighting, by using a high value of ambient light, and by ether reducing the directional light intensity, or increasing the specularity so that that the directional light mostly contributes highlights.
- I chose to use equirectangular projections because they're widely available, quite intuitive, and make reasonably efficient use of the image space.
  • Like 8
Share this post
Link to post
Nice new feature.
Handy for glass text without needing an outside map.  I envy you coding guys ...
  • Like 4
Share this post
Link to post
Now, this looks awesome!  Did you use @dipstick 's emap?  Looks like it.  I have something to play with!
Thank you MJW!   Will it give results similiar to this (this is what we were trying to duplicate; link from dipstick):   Bevel Reflect
Edit:  At least that's what I was trying to do. I used your EdgeShader plugin to get some height in the middle of the letters to give it a beveled, though rounded look.
That is also awesome Welshy!!   What steps did you use?  What map did you use?  Oh, darn...just do a tutorial...:P
Share this post
Link to post
Thanks, but needs fine tuning a bit.  I used the texture from my stamped text tutorial.  The Planetoid made one.
I will get something set out as a tut, BTH currently got so much going on in my life - don't hold your breath or you may turn blue :/
Same technique but using a different Splinter Blend Mode when blurring.  Went a bit scratched ... I think it was a couple of layers of Negation :/
Edited by welshblue
  • Like 4
Share this post
Link to post
I got some interesting results. I see how the new mapping method 'wraps' around the object.
I used dip's original emap and made more severe modifications to it.
I'll be playing with this for sure!  Thank you!   :D
  • Like 4
Share this post
Link to post
@lynxster4 and @dipstick ... really nice results.  What font did you use Dip' ?  Maybe it's me, but I'm finding certain fonts give better results
@MJW ... this is such a great addition to the arsenal Texture Shader had already.
I had 2 choices ... try and perfect 'glass' or find a new life insurance quote that means I can afford to eat before getting rich when I die
... guess what won out when I realised my wife and daughter will spend it on shoes, my son urinating it against a wall and I'll get flowers maybe twice a year :lol:
Edited by welshblue
  • Like 2
Share this post
Link to post
That is a certainty.  Thicker fonts give better results!   ;)
Share this post
Link to post
I've released Version 2.3.0. I added a new mapping method called Gradient Map (Equirectangular).  This mapping mode is similar to the reflection mapping mode, but instead of using the reflection vector, it uses the gradient vector. It probably has fewer uses then reflection mapping, but provides an extra option. When used with blurry clipboard images, it can simulate diffuse light sources.
EDIT: I probably should mention that "gradient" refers to the slope of the height-map surface, not to a color gradient. I considered calling it Normal Map, but that also has two possible meanings.
  • Like 2
Share this post
Link to post
Me three :( - waiting with bated breath :lol:.  Just love @MJW's Plugins <3
Share this post
Link to post
