iamnoob Posted June 7, 2015 Share Posted June 7, 2015 I've noticed this for awhile now: PDN almost always adds or subtracts one saturation/lightness/etc. point from what you select. For example, say I change a green color's saturation to 50 and then add it to my canvas; if I select a different color first(this seems to "reset" it somehow) and then re-select that green color, chances are it will display either 49/51 saturation instead of the 50 I chose. This happens almost always and should be easy to reproduce. Quote Link to comment Share on other sites More sharing options...
midora Posted June 7, 2015 Share Posted June 7, 2015 You have to know that Paint.NETs internal color representation is RGB. There is always a rounding problem converting HSV -> RGB -> HSV. 1 Quote Link to comment Share on other sites More sharing options...
iamnoob Posted June 7, 2015 Author Share Posted June 7, 2015 You have to know that Paint.NETs internal color representation is RGB. There is always a rounding problem converting HSV -> RGB -> HSV. So, this actually isn't a bug and there's no way to "fix" it? Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 7, 2015 Share Posted June 7, 2015 Correct. There is no 1:1 correlation from RGB to HSV. The results of conversion contain many decimal places which need to be rounded to integers. This process happens automatically and there is no way to 'force' paint.net to use the HSV values. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
iamnoob Posted June 8, 2015 Author Share Posted June 8, 2015 Correct. There is no 1:1 correlation from RGB to HSV. The results of conversion contain many decimal places which need to be rounded to integers. This process happens automatically and there is no way to 'force' paint.net to use the HSV values. I see. If I printscreen a color off the internet that is listed as having a specific amount of saturation/brightness/etc., paste into PDN, use the color picker and the values are displayed as something else, am I not getting the same exact color from the internet? I mean, it looks the same to me, but the values are different(and not just by one point, sometimes by several), so I'm just curious. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 8, 2015 Share Posted June 8, 2015 Monitors interpret colors differently, so your view of an image on the internet might be different from mine. Consider that my monitor lives in a fairly dim room. I have the Brightness set down slightly from the default. If I had a lot of ambient light I may need to turn the brightness up a little more. Imagine what this does to an image I view from the internet. There are different color spaces to consider. 8-bit, 16-bit RGB and CYMK. All are valid and all can be used to create an image. No you're not going to get the same "internet" color - there is no such thing. Even your RGB's are bound to be slightly different to mine and everyone else's. If you really need this level of accuracy you would be better working in the CYMK color space with something like PS. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
