Twistedlicorice Posted May 11, 2015 Share Posted May 11, 2015 I want to edit an image into paint.net that is 1920x1080. However, when I copy it into paint.net it appears that the image is much smaller, as shown in the second image. (both images that are shown are 1920x1080, yet this forum did not allow me to post that picture. I want the image to be its size without me having to stretch out the image, and therefore reducing the quality. Any tips? Quote Link to comment Share on other sites More sharing options...
skullbonz Posted May 11, 2015 Share Posted May 11, 2015 (edited) What is happening is your canvas size is too big that you start with. I usually drag and drop the image into pdn and when the prompt comes up I select "Open". Another way would be to right click on the image and select "Open with" and "paint.net". All this copy and paste people do seems like a hard way of doing things to me. It took decades to teach people how to copy and paste and now they can't stop using it,lol. Edited May 11, 2015 by skullbonz Quote http://forums.getpaint.net/index.php?/topic/21233-skullbonz-art-gallery Link to comment Share on other sites More sharing options...
Twistedlicorice Posted May 11, 2015 Author Share Posted May 11, 2015 I don't think that's necessarily my problem, as my problem is that all of my images are being shown as the wrong sizes. Hopefully this helps. Quote Link to comment Share on other sites More sharing options...
MJW Posted May 11, 2015 Share Posted May 11, 2015 I suspect the image you're cutting isn't 1920x1080. Maybe you're getting the thumbnail version instead of the actual image. If it's from a webpage or something like that, and assuming you haven't tried this already, before you cut it, right-click and select "View Image Info." If it says the size is 1920x1080, try cutting and pasting into PDN with "Paste into New Image." If it's considerably less than 1920x1080, figure out why you're using the wrong version of the image. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted May 11, 2015 Share Posted May 11, 2015 I think MJW has it. The image doesn't appear to be anything like the dimensions you posted. Try this: Copy the image to the clipboard from wherever you got it. Next create a new image with PDN (File>New). The new canvas will be the correct size to house the clipboard image. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Pixey Posted May 11, 2015 Share Posted May 11, 2015 I may be doing it wrong, but when this ever happens to me I go to - Image - Crop to Selection - and then the canvas adjusts. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
skullbonz Posted May 11, 2015 Share Posted May 11, 2015 Many different ways to do the same thing. Quote http://forums.getpaint.net/index.php?/topic/21233-skullbonz-art-gallery Link to comment Share on other sites More sharing options...
