pie75 0 Posted April 26, 2015 Share Posted April 26, 2015 hello there as the tile states, i have a problem, my custom metal slug character sprite sheet has refused to open on paint.net, it has an error every time: " System.IO.EndOfStreamException: Attempted to read past the end of the stream. at PaintDotNet.Document.FromStream(Stream stream) in d:\src\pdn\paintdotnet\src\Data\Document.cs:line 1350 at PaintDotNet.FileType.Load(Stream input) in d:\src\pdn\paintdotnet\src\Data\FileType.cs:line 477 at PaintDotNet.Functional.Func.Eval[T1,TRet](Func`2 f, T1 arg1) in d:\src\pdn\paintdotnet\src\Base\Functional\Func.cs:line 158 " This problem occurred when my computer had crashed into a blue screen while editing one of my other pdn, the one i was editing survived(somewhat), however this one gained some sort of curruption, and I was wondering if there was a way to fix it? if anybody knows a way or can fix it ,it would be greatly apprieciated , however if it is un-fixable i thank you for reading this post, and would like you to inform me, so i may start over, and hopefully finish it . the file could not be attached below Quote Link to post Share on other sites
Ego Eram Reputo 2,789 Posted April 26, 2015 Share Posted April 26, 2015 No file attached? Try running this plugin http://forums.getpaint.net/index.php?/topic/31715-whats-it-tools-effect-plugin/ Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
pie75 0 Posted April 27, 2015 Author Share Posted April 27, 2015 (edited) not sure how this is supposed to help , but thanks for the contribution I know that it is a PDN already, I made it in paint.net, but this plugin says it could not identify, the file Edited April 27, 2015 by pie75 Quote Link to post Share on other sites
midora 228 Posted April 27, 2015 Share Posted April 27, 2015 If the tools tells you that the basic operation of identifying the file does not work then you can expect that the structure of the file is damaged in a way that there is little chance to restore any part. Because most parts of the file are compressed and without any structure information you can not decompress anything. Sorry. Quote Link to post Share on other sites
pie75 0 Posted April 27, 2015 Author Share Posted April 27, 2015 oh, okay then thanks midora , gonna start over now Quote Link to post Share on other sites
Ego Eram Reputo 2,789 Posted April 27, 2015 Share Posted April 27, 2015 Can you zip the file and attach it? Someone might be able to restore some of it. Wouldn't hurt to try. Have you tried right clicking on the file + Restore Previous Version? Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
Rick Brewster 1,766 Posted April 28, 2015 Share Posted April 28, 2015 Your PDN file is corrupt and cannot be saved. Sorry ... blue screens can do that :-\ Make sure that whatever disk or drive you're saving your files to is using the NTFS file system, and not FAT or FAT32. The latter two do not permit Paint.NET to use something called transactions, which almost completely prevent this problem (if it happens while saving, that is). I'm assuming you're using a recent version of Paint.NET (like 4.0.5), by the way. Some old-but-still-in-wide-use versions (3.5.something) don't support the transactions stuff and you should avoid them. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
Maximilian 1,927 Posted April 29, 2015 Share Posted April 29, 2015 Does 3.5.11 support transactions? Quote Link to post Share on other sites
Rick Brewster 1,766 Posted April 29, 2015 Share Posted April 29, 2015 Yes, but why don't you have 4.0 installed? That's a rhetorical question. Please go install it asap. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
Maximilian 1,927 Posted April 29, 2015 Share Posted April 29, 2015 Will do asap! Thanks for the reply! Quote Link to post Share on other sites
