Uesserukun Posted April 24, 2015 Share Posted April 24, 2015 Hello forummers What is an effective way to create alias? The alias has to be semi-transparent as well, something like this: http://puu.sh/hpzF9/b6f034995f.png Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted April 24, 2015 Share Posted April 24, 2015 Sounds like you're looking for anti-alias. This plugin is probably your best bet:http://forums.getpaint.net/index.php?showtopic=16643 Menu > Effects > ObjectAA's Asistantsoften the edges , and adjust alpha. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Maximilian Posted April 25, 2015 Share Posted April 25, 2015 Most times we want to anti-alias an image, like toe_head said above. However, if what you really want is to actually alias an image, you may be interested in Mike Ryan's Alias plugin (in any case, follow both links and see if either plugin does what you want). Quote Link to comment Share on other sites More sharing options...
