Is there a way to draw crayon or other style arrows in paint.net?
ShuckyDucky
I know how to do the most basic arrows, but it looks like the line style is fixed, you can't use a paint brush or any other drawing tool for the line, its just a line and perhaps some strange windows 3.1 era pixel tile patterns.
http://www.clker.com/cliparts/S/Q/d/C/3/n/arrow-left.svg
http://thumbs.dreamstime.com/z/lightning-sketch-crayon-painted-flash-electricity-symbol-white-back-35322751.jpg
Any way to do that kind of thing?  Crayon or inky type arrows?
Hi ShuckyDucky - welcome to the forum :D
Right now your best bet is to use a custom brush.
This plugin makes certain image files available as a brush Custom Brushes
The line type of arrow may be possible in the near future. The Dwarf Horde™ is currently working on a plugin to create shapes just like this.
For the chalk type arrow - try modifying this tutorial: http://forums.getpaint.net/index.php?/topic/21552-chalk-text/
  • Upvote 3
Thanks, I guess i'll just wait for the Dwarf Horde plugin then, I just wanted a fast way to edit pictures with a caption.
