UberKiller Posted March 27, 2015 Share Posted March 27, 2015 I was interested in figuring this out. I plan to make graffiti for my scene and the Minecraft 3D animation program I use has some odd alpha bug to where semi-transparent pixels cause them to phase through everything, generating this effect. The newer version will fix it, but that's in a year or so ahead of me. The only way to get around it is to make things fully transparent or fully opaque. An image can have both, but cannot be in between. Thus the graffiti I am using I used the cut color plugin which yielded positive results. Yet there was still parts of it left. I want to either: Make the semi-transluscent areas totally opaque Make the semi-transluscent areas totally invisible. Is there a way to accomplish this in standard Paint.Net or will I need a plugin to achieve it. If so, how would I? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted March 27, 2015 Share Posted March 27, 2015 These plugins spring to mind Alpha Transform and Alpha Threshold. I'm sure there are many more which will do the job just as well. 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
UberKiller Posted March 27, 2015 Author Share Posted March 27, 2015 (edited) These plugins spring to mind Alpha Transform and Alpha Threshold. I'm sure there are many more which will do the job just as well. Hmm, i'll give them a shot. Thanks for the quick reply! EDIT: Alpha Threshold is exactly what I was looking for. Thanks a million! Edited March 28, 2015 by UberKiller Quote Link to comment Share on other sites More sharing options...
