Problem with some plugins after pgm update
I got the message to update the program, I did with no problem.  Now, days later I'm trying to use Feather and when I click on it it throws an error msg that prompts me to restart the pgm.  I downloaded a new plugin pack specifically for 40 but am getting the same errors....help!
You're probably using an older version of Feather.  Hover your mouse over the Feather entry in the menu and it will show the file (dll) name in a tool tip.   Tell us what that filename is and we might be able to provide a solution.
This should be posted in the Feather thread (where you downloaded it from).  I'll sort that out for you by merging this thread - when I get time!
