TechnicGeek Posted March 26, 2015 Share Posted March 26, 2015 (edited) Hello everyone. I am interested to know if it's possible to reproduce in Paint.NET what you observe in this video where person adjusts colors in Photoshop: http://tinypic.com/player.php?v=1ioi8m&s=8#.VRRLZfnxLwo Would it be possible and close enough or there is other free tools that can do better job at that? Thanks Edited March 26, 2015 by TechnicGeek Quote Link to comment Share on other sites More sharing options...
midora Posted March 26, 2015 Share Posted March 26, 2015 Hi TechnicGeek, the short answer to a short general question is: Yes. The little bit longer answer is. There are all kind of adjustments in - I guess - the Adjustments menu of Paint.NET. Plus there are a lot of plugins available. Still you have to open the application once and check out what is available for your needs. If there is a specific question left then someone may guide you. Quote Link to comment Share on other sites More sharing options...
TechnicGeek Posted March 26, 2015 Author Share Posted March 26, 2015 Hello. The purpose is to make photos that have not enough lighting white like was done in video above. Actually the photo was more like dark orange and with magic of color adjustments photo was now on clean whit backgorund. Also details on object that were not seen before became more visible which I assume might have to do with gamma. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted March 26, 2015 Share Posted March 26, 2015 Are you looking for a White Balance? Try this plugin White Balance or White point Correction. Other than that you can use Adjustments > Curves or Adjustments > Levels. 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
