Animated Images
midora
  • 3 weeks later...
Mmmh, if I select from requester to open a AGIF file, Windows file requester will be correctly restricted to aGIFs only in that directory, skipping normal GIF files:
but then when I proceed loading those .gif as AGIF they won't get loaded as agif :( Is this a bug? I know I can rename them .agif to load them correctly as animated gifs, but I wanted to keep them as .gif and force-load them as AGIF from within Paint.net...
Am I doing something wrong? Is this impossible to do?
Edited by hexaae
1 minute ago, hexaae said:
Mmmh, if I select from requester to open a AGIF file, Windows file requester will be correctly restricted to aGIFs only, but when I load those .gif they get loaded as gif and not as agif :( Is this a bug? I know I can reneame them .agif to load them correctly as animated gifs, but I wanted to keep them as .gif and force-load them as AGIF from within Paint.net...
Because of a quirk of the Paint.NET file type plugin system, you can't override built-in file types.  Therefore, to support animated gif files, you must first install the agif plugin, then rename your file from MyFile.GIF to MyFile.AGIF and open it in Paint.NET.  When finished making changes, you need to save your animated gif as MyFile.AGIF. Finally, to see the results in Windows/Explorer/etc., you must rename your MyFile.AGIF to MyFile.GIF.
If you can't see the file extensions in file explorer, you need to enable that in the file explorer ribbon.
  • You're a Smart Cookie! 1
Click to play:
Oh :( Thank you from prompt reply. Will this change in the future for Paint.net? At least when force-loading a specific format changing file type in the file-requester... Of course keeping default filter will give priority to built-in formats, but when choosing a specific filter I expected Paint.net to ignore built-in filter.
Edited by hexaae
Hi, I am sorry if this has been answered, my older brother usually helps me with this sort of stuff but we do not live near each other anymore. I can no longer get this plugin to work, I tried saving as a "gif" and renaming to "agif". Ive also replaced the save files for this plugin. Making gifs was really fun and I haven't been able to do it in a long time. I primarily use pantdotnet over any other program. I tried using Gimp but I hate it. Any help, advice, or tips would be appreciated.
Hello @DazedSparrow and welcome to the forum :)
Hopefully going over the following tutorial will help you to see how @Midora's Plugin is used to make an animation in paintdotnet :)  Pay particular attention to where the Plugin .dll's are placed into PDN's folders.
Thank you! I will try this out, I have used this plugin before but it stopped working some time ago- but it doesn't hurt to try again! I will look this over, thank you so much!
You are welcome @DazedSparrow If you go to the first page you will see that this Plugin was revamped in 2019, so you will have to download it anew :)
@DragonFox Do you have the latest download, from the first page, as it has been re-vamped since the original Plugin was created?
Hi,
Thank you all for the great tool and your support. I'm trying to open my GIF but got an error in the very end of file's opening process (full details in the file below). Is there any ideas how I can fix it?
Exception:
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
   at System.Buffer.__Memmove(Byte* dest, Byte* src, UInt64 len)
   at System.Buffer._Memmove(Byte* dest, Byte* src, UInt64 len)
   at System.Buffer.Memmove(Byte* dest, Byte* src, UInt64 len)
   at PaintDotNet.Surface.CopySurface(ISurface`1 source) in D:\src\pdn\src\Core\Surface.cs:line 1162
   at PaintDotNet.Surface.Clone() in D:\src\pdn\src\Core\Surface.cs:line 1498
   at PropertyBasedFileTypes.AgifInternal.Load(Stream input)
   at PaintDotNet.FileType.Load(Stream input) in D:\src\pdn\src\Data\FileType.cs:line 512
   at PaintDotNet.Functional.Func.Eval[T1,TRet](Func`2 f, T1 arg1) in D:\src\pdn\src\Base\Functional\Func.cs:line 158
Details.txt
Edited by AlexY
Shorten the main message
52 minutes ago, DragonFox said:
1024x1024 pixels.
That's big.  Just to re-cap is it crashing PDN when you import the GIF (which should have .agif at the end of the saved file), or are you trying to make a GIF with this Plugin?
When I have used this Plugin, my images are usually no bigger than 500 x 200.
Saving. I see the progress bar become full, then the plugin crashes
Hmm... to be honest I think it's because the images are just too big.
You are using Save As Agif?
I just tested the Plugin and it's working fine:
@DragonFox is using the AGIF plugin, the crash is occurring when the AGIF plugin attempts to load the preview image in the save dialog.
If the images are family friendly, uploading the zipped PDN file would help in debugging this issue.
I copied the crash log text from the PasteBin link:
Spoiler
Exception:
   at PropertyBasedFileTypes.AgifInternal.Load(Stream input) in C:\Users\Kalama\Documents\GitHub\ImAGIF.FileTypeRick\PropertyBasedFileTypes\AgifInternal.cs:line 39
   at PaintDotNet.Dialogs.SaveConfigDialog.<>c__DisplayClass49_0.<UpdatePreviewAsync>b__0() in D:\src\pdn\src\PaintDotNet\Dialogs\SaveConfigDialog.cs:line 622
   at System.Threading.Tasks.Task.Execute()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at PaintDotNet.Dialogs.SaveConfigDialog.<UpdatePreviewAsync>d__49.MoveNext() in D:\src\pdn\src\PaintDotNet\Dialogs\SaveConfigDialog.cs:line 632
Diagnostics:
Application                                          paint.net 4.2.14 (Final 4.214.7601.39231)
Build Date                                           Friday, October 23, 2020
Install type                                         Classic
Hardware accelerated rendering (GPU)                 False
Animations                                           True
DPI                                                  96 (1.00x scale)
Language                                             en-US
OS                                                   Windows 8.1 x64 (6.3.9600.0) (0x65)
.NET Runtime                                         4.0.30319.42000
Physical Memory                                      8,073 MB
CPU                                                  Intel(R) Core(TM) i7-5500U CPU @ 2.40GHz
    Speed                                            ~2394 MHz
    Cores / Threads                                  2 / 4
    Features                                         SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2
Pointer                                              Touchscreen
    Type                                             Touch
    Contacts                                         10
Video Card                                           NVIDIA GeForce 940M
    Dedicated Video RAM                              1,970 MB
    Dedicated System RAM                             0 MB
    Shared System RAM                                4,036 MB
    Vendor ID                                        0x10DE
    Device ID                                        0x1347
    Subsystem ID                                     0x391717AA
    Revision                                         162
    LUID                                             0x000102E7
    Flags                                            None
    Graphics Preemption                              DmaBufferBoundary
    Compute Preemption                               DmaBufferBoundary
    Outputs                                          1
    Feature Level                                    Direct3D_11_0
    DXGI Formats                                     A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float
    Buffer Precision                                 UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc
Video Card                                           Intel(R) HD Graphics 5500
    Dedicated Video RAM                              128 MB
    Shared System RAM                                3,840 MB
    Vendor ID                                        0x8086
    Device ID                                        0x1616
    Revision                                         9
    LUID                                             0x0000FF9E
    Flags                                            None
    Graphics Preemption                              TriangleBoundary
    Compute Preemption                               ThreadGroupBoundary
    Outputs                                          0
    Feature Level                                    Direct3D_11_1
Video Card                                           Microsoft Basic Render Driver
    Dedicated Video RAM                              0 MB
    Shared System RAM                                256 MB
    Vendor ID                                        0x1414
    Device ID                                        0x008C
    Subsystem ID                                     0x00000000
    Revision                                         0
    LUID                                             0x00010280
    Flags                                            Software
    Graphics Preemption                              PrimitiveBoundary
    Compute Preemption                               DispatchBoundary
    Outputs                                          0
Managed assemblies                                   32
    mscorlib                                         mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    PaintDotNet                                      PaintDotNet, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null
    PaintDotNet.Core                                 PaintDotNet.Core, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null
    PaintDotNet.Base                                 PaintDotNet.Base, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null
    WindowsBase                                      WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    System.Core                                      System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    System                                           System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    System.Drawing                                   System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    PresentationFramework                            PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    PresentationCore                                 PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    System.Windows.Forms                             System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    PaintDotNet.SystemLayer                          PaintDotNet.SystemLayer, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null
    PaintDotNet.Framework                            PaintDotNet.Framework, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null
    PaintDotNet.Resources                            PaintDotNet.Resources, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null
    PaintDotNet.Effects                              PaintDotNet.Effects, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null
    PaintDotNet.Data                                 PaintDotNet.Data, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null
    PaintDotNet.SystemLayer.Native.x64               PaintDotNet.SystemLayer.Native.x64, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null
    System.Configuration                             System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Xml                                       System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    System.Xaml                                      System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    System.Runtime.CompilerServices.Unsafe           System.Runtime.CompilerServices.Unsafe, Version=4.0.6.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    ImAGIF.FileType                                  ImAGIF.FileType, Version=0.13.0.21358, Culture=neutral, PublicKeyToken=null
    WebPFileType                                     WebPFileType, Version=1.3.4.0, Culture=neutral, PublicKeyToken=null
    DdsFileTypePlus                                  DdsFileTypePlus, Version=1.10.7.0, Culture=neutral, PublicKeyToken=null
    AvifFileType                                     AvifFileType, Version=1.1.4.0, Culture=neutral, PublicKeyToken=null
    System.Collections.Immutable                     System.Collections.Immutable, Version=1.2.5.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Accessibility                                    Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Buffers                                   System.Buffers, Version=4.0.3.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
    System.Memory                                    System.Memory, Version=4.0.1.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
    ColorClearer                                     ColorClearer, Version=1.1.6009.41762, Culture=neutral, PublicKeyToken=null
    K4os.Compression.LZ4                             K4os.Compression.LZ4, Version=1.1.11.0, Culture=neutral, PublicKeyToken=2186fa9121ef231d
    System.Xml.Linq                                  System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Native modules                                       222
    PaintDotNet.exe                                  C:\Program Files\paint.net\PaintDotNet.exe, version=4.214.7601.39231
    ntdll.dll                                        C:\WINDOWS\SYSTEM32\ntdll.dll, version=6.3.9600.18217 (winblue_ltsb.160124-0053)
    MSCOREE.DLL                                      C:\WINDOWS\SYSTEM32\MSCOREE.DLL, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    KERNEL32.dll                                     C:\WINDOWS\system32\KERNEL32.dll, version=6.3.9600.18217 (winblue_ltsb.160124-0053)
    KERNELBASE.dll                                   C:\WINDOWS\system32\KERNELBASE.dll, version=6.3.9600.18217 (winblue_ltsb.160124-0053)
    ADVAPI32.dll                                     C:\WINDOWS\system32\ADVAPI32.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    msvcrt.dll                                       C:\WINDOWS\system32\msvcrt.dll, version=7.0.9600.17415 (winblue_r4.141028-1500)
    sechost.dll                                      C:\WINDOWS\SYSTEM32\sechost.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    RPCRT4.dll                                       C:\WINDOWS\system32\RPCRT4.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    SspiCli.dll                                      C:\WINDOWS\system32\SspiCli.dll, version=6.3.9600.18454 (winblue_ltsb.160820-0600)
    mscoreei.dll                                     C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version=4.8.4018.0 built by: NET48REL1LAST_C
    SHLWAPI.dll                                      C:\WINDOWS\system32\SHLWAPI.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    combase.dll                                      C:\WINDOWS\SYSTEM32\combase.dll, version=6.3.9600.18666 (winblue_ltsb.170415-2040)
    USER32.dll                                       C:\WINDOWS\system32\USER32.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    GDI32.dll                                        C:\WINDOWS\system32\GDI32.dll, version=6.3.9600.19539 (winblue_ltsb_escrow.191016-1700)
    IMM32.DLL                                        C:\WINDOWS\system32\IMM32.DLL, version=6.3.9600.17415 (winblue_r4.141028-1500)
    MSCTF.dll                                        C:\WINDOWS\system32\MSCTF.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    kernel.appcore.dll                               C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    VERSION.dll                                      C:\WINDOWS\SYSTEM32\VERSION.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    clr.dll                                          C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll, version=4.8.4069.0 built by: NET48REL1LAST_B
    VCRUNTIME140_CLR0400.dll                         C:\WINDOWS\SYSTEM32\VCRUNTIME140_CLR0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM
    ucrtbase_clr0400.dll                             C:\WINDOWS\SYSTEM32\ucrtbase_clr0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM
    psapi.dll                                        C:\WINDOWS\system32\psapi.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    mscorlib.ni.dll                                  C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\mscorlib\7fab566d563ec7b74b7696d436ef82d6\mscorlib.ni.dll, version=4.8.4069.0 built by: NET48REL1LAST_B
    ole32.dll                                        C:\WINDOWS\system32\ole32.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    CRYPTBASE.dll                                    C:\WINDOWS\SYSTEM32\CRYPTBASE.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    bcryptPrimitives.dll                             C:\WINDOWS\SYSTEM32\bcryptPrimitives.dll, version=6.3.9600.18895 (winblue_ltsb.180101-1800)
    uxtheme.dll                                      C:\WINDOWS\system32\uxtheme.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    tiptsf.dll                                       C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    OLEAUT32.dll                                     C:\WINDOWS\system32\OLEAUT32.dll, version=6.3.9600.19460
    CRYPTSP.dll                                      C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    rsaenh.dll                                       C:\WINDOWS\system32\rsaenh.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    bcrypt.dll                                       C:\WINDOWS\SYSTEM32\bcrypt.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    System.ni.dll                                    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System\b4f96cff0dcbbbafc191fb13a8166383\System.ni.dll, version=4.8.4001.0 built by: NET48REL1LAST_C
    System.Core.ni.dll                               C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Core\6d2b3ec7c816fa571e3386dee4d9441c\System.Core.ni.dll, version=4.8.4110.0 built by: NET48REL1LAST_B
    WindowsBase.ni.dll                               C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\WindowsBase\53a028eb88ae216cd9c8a63e87eec950\WindowsBase.ni.dll, version=4.8.4110.0 built by: NET48REL1LAST_B
    System.Drawing.ni.dll                            C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Drawing\f7aa008075f1441ded82188fa5cde5e9\System.Drawing.ni.dll, version=4.8.3761.0 built by: NET48REL1
    PresentationCore.ni.dll                          C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PresentationCore\9a66843054f6b803eb9ece35e1a6bb6c\PresentationCore.ni.dll, version=4.8.4110.0 built by: NET48REL1LAST_B
    PresentationFramework.ni.dll                     C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Presentatio5ae0f00f#\5049cbdef9aeb1afcac292e59fe12dbc\PresentationFramework.ni.dll, version=4.8.4110.0
    PaintDotNet.Base.ni.dll                          C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Base\85ce905de20f444e032fbe173b796ee1\PaintDotNet.Base.ni.dll, version=4.214.7601.39231
    System.Windows.Forms.ni.dll                      C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Windows.Forms\f55f4ff42a52b04561c6e19f8c1363b9\System.Windows.Forms.ni.dll, version=4.8.4042.0 built by: NET48REL1LAST_C
    PaintDotNet.SystemLayer.ni.dll                   C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet500b2e4f#\dcc75562f440e33944ecef8bd4fca7c2\PaintDotNet.SystemLayer.ni.dll, version=4.214.7601.39231
    PaintDotNet.Core.ni.dll                          C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Core\5c93745358c89b61bcc97592b8633adf\PaintDotNet.Core.ni.dll, version=4.214.7601.39231
    PaintDotNet.Resources.ni.dll                     C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet26779e70#\4de7e21637e9d0c407bb4236ad98ce0c\PaintDotNet.Resources.ni.dll, version=4.214.7601.39231
    PaintDotNet.Framework.ni.dll                     C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet7afaaa15#\bbf90c78f6a46586f1e1dc5fcaeda635\PaintDotNet.Framework.ni.dll, version=4.214.7601.39231
    PaintDotNet.Data.ni.dll                          C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Data\cb1bfff905856189d9cc15eaebb9b33a\PaintDotNet.Data.ni.dll, version=4.214.7601.39231
    PaintDotNet.Effects.ni.dll                       C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Effects\65acf8e396053f2948eebbdcd64f9c78\PaintDotNet.Effects.ni.dll, version=4.214.7601.39231
    PaintDotNet.ni.exe                               C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet\29c5db96f4bf01f650c094b1a53445ce\PaintDotNet.ni.exe, version=4.214.7601.39231
    dwrite.dll                                       C:\WINDOWS\SYSTEM32\dwrite.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    wpfgfx_v0400.dll                                 C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\wpfgfx_v0400.dll, version=4.8.4110.0 built by: NET48REL1LAST_B
    MSVCP140_CLR0400.dll                             C:\WINDOWS\SYSTEM32\MSVCP140_CLR0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM
    PresentationNative_v0400.dll                     C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\PresentationNative_v0400.dll, version=4.8.4110.0 built by: NET48REL1LAST_B
    shell32.dll                                      C:\WINDOWS\system32\shell32.dll, version=6.3.9600.17031 (winblue_gdr.140221-1952)
    SHCORE.dll                                       C:\WINDOWS\SYSTEM32\SHCORE.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    api-ms-win-core-console-l1-1-0.dll               C:\Program Files\paint.net\Native\X64\api-ms-win-core-console-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-datetime-l1-1-0.dll              C:\Program Files\paint.net\Native\X64\api-ms-win-core-datetime-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-debug-l1-1-0.dll                 C:\Program Files\paint.net\Native\X64\api-ms-win-core-debug-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-errorhandling-l1-1-0.dll         C:\Program Files\paint.net\Native\X64\api-ms-win-core-errorhandling-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-file-l1-1-0.dll                  C:\Program Files\paint.net\Native\X64\api-ms-win-core-file-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-file-l1-2-0.dll                  C:\Program Files\paint.net\Native\X64\api-ms-win-core-file-l1-2-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-file-l2-1-0.dll                  C:\Program Files\paint.net\Native\X64\api-ms-win-core-file-l2-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-handle-l1-1-0.dll                C:\Program Files\paint.net\Native\X64\api-ms-win-core-handle-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-heap-l1-1-0.dll                  C:\Program Files\paint.net\Native\X64\api-ms-win-core-heap-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-interlocked-l1-1-0.dll           C:\Program Files\paint.net\Native\X64\api-ms-win-core-interlocked-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-libraryloader-l1-1-0.dll         C:\Program Files\paint.net\Native\X64\api-ms-win-core-libraryloader-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-localization-l1-2-0.dll          C:\Program Files\paint.net\Native\X64\api-ms-win-core-localization-l1-2-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-memory-l1-1-0.dll                C:\Program Files\paint.net\Native\X64\api-ms-win-core-memory-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-namedpipe-l1-1-0.dll             C:\Program Files\paint.net\Native\X64\api-ms-win-core-namedpipe-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-processenvironment-l1-1-0.dll    C:\Program Files\paint.net\Native\X64\api-ms-win-core-processenvironment-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-processthreads-l1-1-0.dll        C:\Program Files\paint.net\Native\X64\api-ms-win-core-processthreads-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-processthreads-l1-1-1.dll        C:\Program Files\paint.net\Native\X64\api-ms-win-core-processthreads-l1-1-1.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-profile-l1-1-0.dll               C:\Program Files\paint.net\Native\X64\api-ms-win-core-profile-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-rtlsupport-l1-1-0.dll            C:\Program Files\paint.net\Native\X64\api-ms-win-core-rtlsupport-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-string-l1-1-0.dll                C:\Program Files\paint.net\Native\X64\api-ms-win-core-string-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-synch-l1-1-0.dll                 C:\Program Files\paint.net\Native\X64\api-ms-win-core-synch-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-synch-l1-2-0.dll                 C:\Program Files\paint.net\Native\X64\api-ms-win-core-synch-l1-2-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-sysinfo-l1-1-0.dll               C:\Program Files\paint.net\Native\X64\api-ms-win-core-sysinfo-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-timezone-l1-1-0.dll              C:\Program Files\paint.net\Native\X64\api-ms-win-core-timezone-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-core-util-l1-1-0.dll                  C:\Program Files\paint.net\Native\X64\api-ms-win-core-util-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-crt-conio-l1-1-0.dll                  C:\Program Files\paint.net\Native\X64\api-ms-win-crt-conio-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-crt-convert-l1-1-0.dll                C:\Program Files\paint.net\Native\X64\api-ms-win-crt-convert-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-crt-environment-l1-1-0.dll            C:\Program Files\paint.net\Native\X64\api-ms-win-crt-environment-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-crt-filesystem-l1-1-0.dll             C:\Program Files\paint.net\Native\X64\api-ms-win-crt-filesystem-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-crt-heap-l1-1-0.dll                   C:\Program Files\paint.net\Native\X64\api-ms-win-crt-heap-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-crt-locale-l1-1-0.dll                 C:\Program Files\paint.net\Native\X64\api-ms-win-crt-locale-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-crt-math-l1-1-0.dll                   C:\Program Files\paint.net\Native\X64\api-ms-win-crt-math-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-crt-multibyte-l1-1-0.dll              C:\Program Files\paint.net\Native\X64\api-ms-win-crt-multibyte-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-crt-private-l1-1-0.dll                C:\Program Files\paint.net\Native\X64\api-ms-win-crt-private-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-crt-process-l1-1-0.dll                C:\Program Files\paint.net\Native\X64\api-ms-win-crt-process-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-crt-runtime-l1-1-0.dll                C:\Program Files\paint.net\Native\X64\api-ms-win-crt-runtime-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-crt-stdio-l1-1-0.dll                  C:\Program Files\paint.net\Native\X64\api-ms-win-crt-stdio-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-crt-string-l1-1-0.dll                 C:\Program Files\paint.net\Native\X64\api-ms-win-crt-string-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-crt-time-l1-1-0.dll                   C:\Program Files\paint.net\Native\X64\api-ms-win-crt-time-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    api-ms-win-crt-utility-l1-1-0.dll                C:\Program Files\paint.net\Native\X64\api-ms-win-crt-utility-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    ucrtbase.dll                                     C:\Program Files\paint.net\Native\X64\ucrtbase.dll, version=10.0.17134.12 (WinBuild.160101.0800)
    vcruntime140.dll                                 C:\Program Files\paint.net\Native\X64\vcruntime140.dll, version=14.27.29016.0 built by: vcwrkspc
    vcruntime140_1.dll                               C:\Program Files\paint.net\Native\X64\vcruntime140_1.dll, version=14.27.29016.0 built by: vcwrkspc
    msvcp140.dll                                     C:\Program Files\paint.net\Native\X64\msvcp140.dll, version=14.27.29016.0 built by: vcwrkspc
    msvcp140_1.dll                                   C:\Program Files\paint.net\Native\X64\msvcp140_1.dll, version=14.27.29016.0 built by: vcwrkspc
    msvcp140_2.dll                                   C:\Program Files\paint.net\Native\X64\msvcp140_2.dll, version=14.27.29016.0 built by: vcwrkspc
    msvcp140_codecvt_ids.dll                         C:\Program Files\paint.net\Native\X64\msvcp140_codecvt_ids.dll, version=14.27.29016.0 built by: vcwrkspc
    vcomp140.dll                                     C:\Program Files\paint.net\Native\X64\vcomp140.dll, version=14.27.29016.0 built by: vcwrkspc
    PaintDotNet.SystemLayer.Native.x64.ni.dll        C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNetc8826574#\f348c5e4447d9ffc6a15d1e2ac81b423\PaintDotNet.SystemLayer.Native.x64.ni.dll, version=4.214.7601.39231
    PaintDotNet.SystemLayer.Native.x64.dll           C:\Program Files\paint.net\PaintDotNet.SystemLayer.Native.x64.dll, version=4.214.7601.39231
    PROPSYS.dll                                      C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.00.9600.17031 (winblue_gdr.140221-1952)
    gdiplus.dll                                      C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.9600.19457_none_932f12b9474c9775\gdiplus.dll, version=6.3.9600.19457 (winblue_ltsb.190812-0600)
    WindowsCodecs.dll                                C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=6.3.9600.19262 (winblue_ltsb_escrow.190107-1700)
    clbcatq.dll                                      C:\WINDOWS\SYSTEM32\clbcatq.dll, version=2001.12.10530.17415 (winblue_r4.141028-1500)
    profapi.dll                                      C:\WINDOWS\SYSTEM32\profapi.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    msasn1.dll                                       C:\WINDOWS\system32\msasn1.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    cryptnet.dll                                     C:\WINDOWS\SYSTEM32\cryptnet.dll, version=6.3.9600.18878 (winblue_ltsb.171205-0530)
    CRYPT32.dll                                      C:\WINDOWS\system32\CRYPT32.dll, version=6.3.9600.18372 (winblue_ltsb.160603-0600)
    WLDAP32.dll                                      C:\WINDOWS\system32\WLDAP32.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    System.Configuration.ni.dll                      C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Configuration\f9510d0dd8edf16c84d0497e438c04a7\System.Configuration.ni.dll, version=4.8.3761.0 built by: NET48REL1
    System.Xml.ni.dll                                C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xml\1f9f54067fa94d3e748e5ccfe812fbe2\System.Xml.ni.dll, version=4.8.3761.0 built by: NET48REL1
    dwmapi.dll                                       C:\WINDOWS\system32\dwmapi.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    clrjit.dll                                       C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll, version=4.8.4069.0 built by: NET48REL1LAST_B
    System.Xaml.ni.dll                               C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xaml\6e001644636519af3d7a4ff4ac466030\System.Xaml.ni.dll, version=4.8.4110.0 built by: NET48REL1LAST_B
    System.Runtime.CompilerServices.Unsafe.ni.dll    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Runtea61dfd5#\09e74bb5197cd112ed1f538162366c58\System.Runtime.CompilerServices.Unsafe.ni.dll, version=4.700.20.12001
    dxgi.dll                                         C:\WINDOWS\SYSTEM32\dxgi.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    UIAnimation.dll                                  C:\WINDOWS\System32\UIAnimation.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    comctl32.dll                                     C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.9600.19394_none_62486577ecb635cf\comctl32.dll, version=6.10 (winblue_rtm.130821-1623)
    d2d1.dll                                         C:\WINDOWS\SYSTEM32\d2d1.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    wtsapi32.dll                                     C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    WINSTA.dll                                       C:\WINDOWS\SYSTEM32\WINSTA.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    d3d11.dll                                        C:\WINDOWS\SYSTEM32\d3d11.dll, version=6.3.9600.18437 (winblue_ltsb.160811-0600)
    D3D10Warp.dll                                    C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=6.3.9600.19176 (winblue_ltsb.181006-0600)
    System.Collections.Immutable.ni.dll              C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Coll4a4f96a7#\79cb3465b2f235b4c952fb322dd84a3a\System.Collections.Immutable.ni.dll, version=4.700.20.21406
    oleacc.dll                                       C:\WINDOWS\SYSTEM32\oleacc.dll, version=7.2.9600.17415 (winblue_r4.141028-1500)
    Accessibility.ni.dll                             C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Accessibility\9490ea14a75d8d843aabae761814ed92\Accessibility.ni.dll, version=4.8.3761.0 built by: NET48REL1
    sxs.dll                                          C:\WINDOWS\SYSTEM32\sxs.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    powrprof.dll                                     C:\WINDOWS\SYSTEM32\powrprof.dll, version=6.3.9600.17031 (winblue_gdr.140221-1952)
    System.Buffers.ni.dll                            C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Buffers\6b5b54ba675e4074c038a2c737f23ec6\System.Buffers.ni.dll, version=4.6.28619.01
    winmm.dll                                        C:\WINDOWS\SYSTEM32\winmm.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    WINMMBASE.dll                                    C:\WINDOWS\SYSTEM32\WINMMBASE.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    cfgmgr32.dll                                     C:\WINDOWS\SYSTEM32\cfgmgr32.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    DEVOBJ.dll                                       C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    System.Memory.ni.dll                             C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Memory\339cd9a06c6ee55534276e7aa6a25031\System.Memory.ni.dll, version=4.6.28619.01
    diasymreader.dll                                 C:\Windows\Microsoft.NET\Framework64\v4.0.30319\diasymreader.dll, version=14.8.3761.0 built by: NET48REL1
    explorerframe.dll                                C:\WINDOWS\system32\explorerframe.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    DUser.dll                                        C:\WINDOWS\system32\DUser.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    DUI70.dll                                        C:\WINDOWS\system32\DUI70.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    K4os.Compression.LZ4.ni.dll                      C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\K4os.Compression.LZ4\ad8cca819977aa5ba9e147d4041ea7bb\K4os.Compression.LZ4.ni.dll, version=1.1.11
    System.Xml.Linq.ni.dll                           C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xml.Linq\3e7d4853009a73dba090faaaccb8f46f\System.Xml.Linq.ni.dll, version=4.8.3761.0 built by: NET48REL1
    XmlLite.dll                                      C:\WINDOWS\SYSTEM32\XmlLite.dll, version=6.3.9600.19416 (winblue_ltsb.190629-0600)
    comdlg32.dll                                     C:\WINDOWS\System32\comdlg32.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    SETUPAPI.dll                                     C:\WINDOWS\system32\SETUPAPI.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    Windows.Globalization.dll                        C:\Windows\System32\Windows.Globalization.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    Bcp47Langs.dll                                   C:\Windows\System32\Bcp47Langs.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    globinputhost.dll                                C:\WINDOWS\SYSTEM32\globinputhost.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    atlthunk.dll                                     C:\WINDOWS\SYSTEM32\atlthunk.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    uiautomationcore.dll                             C:\Windows\System32\uiautomationcore.dll, version=7.2.9600.16384 (winblue_rtm.130821-1623)
    StructuredQuery.dll                              C:\WINDOWS\System32\StructuredQuery.dll, version=7.00.9600.19455 (winblue_ltsb.190809-0600)
    actxprxy.dll                                     C:\Windows\System32\actxprxy.dll, version=6.3.9600.19301 (winblue_ltsb_escrow.190225-2000)
    thumbcache.dll                                   C:\Windows\System32\thumbcache.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    SearchFolder.dll                                 C:\WINDOWS\system32\SearchFolder.dll, version=6.3.9600.17031 (winblue_gdr.140221-1952)
    MPR.dll                                          C:\WINDOWS\SYSTEM32\MPR.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    drprov.dll                                       C:\WINDOWS\System32\drprov.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    ntlanman.dll                                     C:\WINDOWS\System32\ntlanman.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    apphelp.dll                                      C:\WINDOWS\SYSTEM32\apphelp.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    davclnt.dll                                      C:\WINDOWS\System32\davclnt.dll, version=6.3.9600.17923 (winblue_ltsb.150701-1108)
    DAVHLPR.dll                                      C:\WINDOWS\System32\DAVHLPR.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    wkscli.dll                                       C:\WINDOWS\System32\wkscli.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    NetworkExplorer.dll                              C:\WINDOWS\system32\NetworkExplorer.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    cscapi.dll                                       C:\WINDOWS\SYSTEM32\cscapi.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    netutils.dll                                     C:\WINDOWS\System32\netutils.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    IDStore.dll                                      C:\WINDOWS\System32\IDStore.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    SAMLIB.dll                                       C:\WINDOWS\System32\SAMLIB.dll, version=6.3.9600.18589 (winblue_ltsb.170204-0600)
    wlidprov.dll                                     C:\WINDOWS\System32\wlidprov.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    dlnashext.dll                                    C:\Windows\System32\dlnashext.dll, version=12.0.9600.16384 (winblue_rtm.130821-1623)
    PlayToDevice.dll                                 C:\Windows\System32\PlayToDevice.dll, version=12.0.9600.16384 (winblue_rtm.130821-1623)
    WS2_32.dll                                       C:\WINDOWS\system32\WS2_32.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    NSI.dll                                          C:\WINDOWS\system32\NSI.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    DevDispItemProvider.dll                          C:\Windows\System32\DevDispItemProvider.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    twinapi.dll                                      C:\Windows\System32\twinapi.dll, version=6.3.9600.17031 (winblue_gdr.140221-1952)
    twinapi.appcore.dll                              C:\Windows\System32\twinapi.appcore.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    NetworkItemFactory.dll                           C:\WINDOWS\system32\NetworkItemFactory.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    dtsh.dll                                         C:\WINDOWS\system32\dtsh.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    FirewallAPI.dll                                  C:\WINDOWS\system32\FirewallAPI.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    LINKINFO.dll                                     C:\WINDOWS\SYSTEM32\LINKINFO.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    AcSignIcon.dll                                   C:\WINDOWS\SYSTEM32\AcSignIcon.dll, version=24.0.47.0.0
    mfc140u.dll                                      C:\WINDOWS\SYSTEM32\mfc140u.dll, version=14.24.28127.4 built by: vcwrkspc
    Comctl32.dll                                     C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.9600.17810_none_34ae2abd958aedeb\Comctl32.dll, version=5.82 (winblue_rtm.130821-1623)
    zipfldr.dll                                      C:\WINDOWS\system32\zipfldr.dll, version=6.3.9600.17031 (winblue_gdr.140221-1952)
    EhStorShell.dll                                  C:\Windows\System32\EhStorShell.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    PortableDeviceApi.dll                            C:\Windows\System32\PortableDeviceApi.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    WINTRUST.dll                                     C:\WINDOWS\system32\WINTRUST.dll, version=6.3.9600.18508 (winblue_ltsb.161004-0600)
    PortableDeviceTypes.dll                          C:\Windows\System32\PortableDeviceTypes.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    mssprxy.dll                                      C:\WINDOWS\system32\mssprxy.dll, version=7.00.9600.19170 (winblue_ltsb.180923-0600)
    EhStorAPI.dll                                    C:\Windows\System32\EhStorAPI.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    npmproxy.dll                                     C:\WINDOWS\System32\npmproxy.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    FunDisc.dll                                      C:\Windows\System32\FunDisc.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    ntshrui.dll                                      C:\WINDOWS\SYSTEM32\ntshrui.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    srvcli.dll                                       C:\WINDOWS\SYSTEM32\srvcli.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    fdproxy.dll                                      C:\Windows\System32\fdproxy.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    fdwcn.dll                                        C:\WINDOWS\System32\fdwcn.dll, version=6.3.9600.18895 (winblue_ltsb.180101-1800)
    wcnapi.dll                                       C:\WINDOWS\System32\wcnapi.dll, version=6.3.9600.18895 (winblue_ltsb.180101-1800)
    fdWNet.dll                                       C:\Windows\System32\fdWNet.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    ATL.DLL                                          C:\Windows\System32\ATL.DLL, version=3.05.2284
    IPHLPAPI.DLL                                     C:\Windows\System32\IPHLPAPI.DLL, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    WINNSI.DLL                                       C:\Windows\System32\WINNSI.DLL, version=6.3.9600.17415 (winblue_r4.141028-1500)
    dfscli.dll                                       C:\WINDOWS\System32\dfscli.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    browcli.dll                                      C:\WINDOWS\System32\browcli.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    mswsock.dll                                      C:\WINDOWS\system32\mswsock.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    DNSAPI.dll                                       C:\WINDOWS\SYSTEM32\DNSAPI.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    nimdnsNSP.dll                                    C:\Program Files\National Instruments\Shared\mDNS Responder\nimdnsNSP.dll, version=215.0.0f0
    nimdnsResponder.dll                              C:\WINDOWS\SYSTEM32\nimdnsResponder.dll, version=215.0.0f0
    MSVCR90.dll                                      C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.8387_none_08e793bfa83a89b5\MSVCR90.dll, version=9.00.30729.8387
    mdnsNSP.dll                                      C:\Program Files\Bonjour\mdnsNSP.dll, version=3,0,0,10
    rasadhlp.dll                                     C:\Windows\System32\rasadhlp.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    fwpuclnt.dll                                     C:\WINDOWS\System32\fwpuclnt.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    dhcpcsvc6.DLL                                    C:\Windows\System32\dhcpcsvc6.DLL, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    dhcpcsvc.DLL                                     C:\Windows\System32\dhcpcsvc.DLL, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    urlmon.dll                                       C:\WINDOWS\System32\urlmon.dll, version=11.00.9600.18378 (winblue_ltsb.160611-0600)
    iertutil.dll                                     C:\WINDOWS\System32\iertutil.dll, version=11.00.9600.16384 (winblue_rtm.130821-1623)
    WININET.dll                                      C:\WINDOWS\System32\WININET.dll, version=11.00.9600.18538 (winblue_ltsb.161112-0600)
    USERENV.dll                                      C:\WINDOWS\System32\USERENV.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    imagehlp.dll                                     C:\WINDOWS\system32\imagehlp.dll, version=6.3.9600.17415 (winblue_r4.141028-1500)
    ncrypt.dll                                       C:\WINDOWS\SYSTEM32\ncrypt.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    NTASN1.dll                                       C:\WINDOWS\SYSTEM32\NTASN1.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
    nvspcap64.dll                                    C:\WINDOWS\system32\nvspcap64.dll, version=3.20.4.14
    ntmarta.dll                                      C:\WINDOWS\SYSTEM32\ntmarta.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
It appears that one of the frames is causing an access violation when the plugin tries to convert it to a Paint.NET Surface.
Thank you @null54 for figuring that out.  I'm afraid I can never work out all that code in the crash log 😊
On 12/18/2020 at 5:35 PM, Pixey said:
Hello @AlexY and Welcome :)
When you saved the GIF to open in PDN, did you add .agif to the file and save as All Files ?
I had just changed extension from .gif to .agif in File Explorer and then tried to open in PDN. It starts opening/processing the file showing process bar and in the very end it crashes firing this error. It looks like a memory leak bug. My GIF is quite large (6 Mb - video converted to GIF) and this might cause the issue.
So, I tried to make it at the original size and I got the same message as you @DragonFox  so I am convinced it's because of the size.
I cropped the size down and then it worked.
I was able to save the full size image using the default settings, what settings are you using?
I hope it is not one of those bugs that only occur on some machines.
