Curve/Lines Help
Welcome to the forum Rich Homie Crab!
Do you mean that your line is composed of dots and you want a continuous line?  This is a setting in the Tool Bar when the line/curve tool is active.
Sounds like you might have the third option selected - click on the first one (Solid) to make the line continuous.
To make the line/curve tool default to this setting, edit the default settings under :Settings:Settings > Tools
