rlg Posted January 5, 2015 Share Posted January 5, 2015 (edited) I tried to make a cover and got as far as using select and the pixel tool and right clicking to angle it, but when I tried to get on with it, the box formed when I selected it, then switched to the pixel tool stayed. Nothing I could do would remove it. When I left clicked and held the button down, it disappeared. But as soon as I let the button go--it came back. What did I do wrong and how can I fix it? My program is one of the older ones of PDN. If that matters. Renee Edited January 6, 2015 by Ego Eram Reputo Turned down the volume (caps) Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted January 6, 2015 Share Posted January 6, 2015 Press the Esc key or Ctrl + D to deselect once you've finished moving or rotating the selection. 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
rlg Posted January 6, 2015 Author Share Posted January 6, 2015 Thank you, thank you, thank you! I wrote it down so this time I'll remember how both to do it and to do it right! Renee Quote Link to comment Share on other sites More sharing options...
