steve200 Posted February 17, 2007 Share Posted February 17, 2007 I just upgraded to 3.0.2580.31 from 2.5 and noticed a possible problem. steps to reproduce: 1) file > new , choose 20 pix by 20 px (small image) 2) change your zoom sufficiently high to see, perhaps 600% 3) press s to select, draw a select region perhaps 10 x 2 (or 2 x 10) 4) press m to change to move/scale mode at this point, recall that the "move" cursor looks like a black triangle and the "scale" cursor looks like a hand. Move your mouse around the image to find a hotspot that will allow you to move the image (i.e. where the cursor becomes a triangle). I cannot find one, the program only offers scale (rotate, etc). To move this area, you have to select a larger block. next, press ctrl+A to select the entire image. Now move the mouse around and you'll find that the "move" hotspot appears about 4-6 pixels from the outer edge... so on a very small selection, it will never be available. ideas 1) as the zoom increases, the hotspot aorund the nubs should *shrink* 2) maybe alt+left mouse is ALWAYS move regardless of how close to the sizing nubs the cursor is BTW, paint.net is a really fantastic program. Quote Link to comment Share on other sites More sharing options...
