Is there any way to measure similarity between two images?
Load the compressed image as new layer above the original  (Layers Menu -> Import from File) and change it's blending mode to XOR (Layers Menu -> Layer Properties -> Blend Mode)
If the two images are identical then you will see a black canvas. If they are not then any differences will appear as strange colors on a black background.
TRsSig.png?raw=1
I knew the xor trick, but is there any way to calculate a number out of it? (Like SSIM)
Edited by yut951121
You could select the black (i.e. common pixels) then invert the selection to reach a count of dissimilar pixels.
you can merge the layers  use this code lab code - it will give you difference percentage
0 would be identical , 100 would be completely different
Menu : Colors -> Difference
#region UICode
bool Amount1 = false; // [0,1] Slider 1 Description
#endregion
    if (!Amount1)
        Amount1=true;
        int totalcount = src.Width * src.Height * 1020;
        int PixelSum = 0;
        ColorBgra CP;
        for (int y = 0; y < src.Height; y++)
            for (int x =0; x < src.Width; x++)
                CP = src[x,y];
                PixelSum  += CP.A;
                PixelSum  += CP.R;
                PixelSum  += CP.G;
                PixelSum  += CP.B;
        double result = (double)PixelSum / (double)totalcount;
        System.Windows.Forms.MessageBox.Show((100 * result).ToString());
Difference.zip
TRsSig.png?raw=1
