Ash111 Posted October 24, 2014 Share Posted October 24, 2014 Hello Guys, I have combined six pictures into a New Paint file, using "Paste into a new layer" option. After saving, I re-opened the saved picture. In the second step, I used eraser, with both Primary and Secondary color option set as "White". After editing, now I am getting black lines on my white background. I did many things but failed. I am using paint since last 6 months, but its the first time I have faced this problem. During erasing, I can see clearly the white/grey marks, but after saving things are different rather than a complete white. Thanks Ash Quote Link to comment Share on other sites More sharing options...
TechnoRobbo Posted October 24, 2014 Share Posted October 24, 2014 Hi Ash, let's clarify a few things I have combined six pictures into a New Paint file, using "Paste into a new layer" option. After saving, I re-opened the saved picture. What format did you save to? PDN,PNG JPG? Was the picture in layers when you opened it? In the second step, I used eraser, with both Primary and Secondary color option set as "White". After editing, now I am getting black lines on my white background. Erasing exposes the layer below the current layer, or transparency if it's the bottom layer. Colors would not affect the eraser. Was black a color in the layer below the eraser? During erasing, I can see clearly the white/grey marks, but after saving things are different rather than a complete white. Where the white grey marks in a pattern - this may mean you've exposed the transparency image. but after saving things are different rather than a complete white Did you save to a jpg format. Saving to a format that doesnt support transparency would change all that transparency to white. Post Edit: If you want to erase to white put a white layer under the working layer. Or use the paintbrush. Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 24, 2014 Share Posted October 24, 2014 Sounds like you might have anti-aliasing artifacts. Try turning anti-aliasing off in the Tool Bar. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Ash111 Posted October 26, 2014 Author Share Posted October 26, 2014 @TechnoRObbo..Dear i combined all these figures, in an new file, which was completely white........After adding text, when i done...i tried to save it in PNG...also in TIFF..in both cases i got the same problem. I did not check antialiasing @Ego, might be the problem. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 26, 2014 Share Posted October 26, 2014 How about uploading the file so we can try and diagnose the problem? Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
